Results 1 to 18 of 18
    Points: 17,477, Level: 32
    neazoi's Avatar
    Jan 2008
    Greece
    3,531
    17,477
    32
    HUM in transmitter PSU
    Hi on my Classic 40 http://qrp.gr/classic40 I am using a SMPSU from a laptop. There is a bit of hum in the received audio on a nearby radio, so I thought this was because of the SMPSU.
    So I used a 24v transformer (ubloaded voltage 28v) and a bridge rectifier and a 4700uF after it to power the transmitter. The hum was much more!
    Why is that? Can it be a transmitter problem or a PSU related?
    Can it be cured?
    Professional engineering is the top, but amateur engineering is more fun.
    It is when you cross the barrier between these two, that things become really fascinating!
    Points: 25,141, Level: 38
    barry's Avatar
    Mar 2005
    California, USA
    4,815
    25,141
    38
    Re: HUM in transmitter PSU
    Aside from the fact that it looks like your transmitter is having a seizure (what was the point of that??), it also looks like you're using a protoboard with wires flying all over the place. That is a sure recipe for hum, noise, etc. Try grounding your audio input and see what happens.
    Points: 13,065, Level: 27
    Apr 2010
    1,993
    13,065
    27
    In addition to proper audio grounding as suggested ,
    add a electrolytic filter cap at the input pin of lm317 at
    the input and ground pins of IC where DC is applied
    in your circuit.
    Points: 14,078, Level: 28
    Aug 2015
    Melbourne
    2,311
    14,078
    28
    laptop psu's do make a lot of CM noise ...
    neazoi's Avatar
    Jan 2008
    Greece
    3,531
    17,477
    32
    Quote Originally Posted by barry View Post
    I did so, the hum was increased!
    Points: 85,362, Level: 71
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    14,045
    85,362
    71
    Sounds like a ground hum loop to me then. There is a difference in voltage between your audio input ground and the LM317 ground. You should have a capacitor (at least 10uF) from the input pin of the LM317 to the emitter of the 2N2222 and the audio ground should also be connected directly to the emitter. Use a star connection, everything audio returned to the same physical point so they must be at the same potential.
    Another thing to watch for is the RF output side. If you have an antenna you may (should) also have a ground connection but it may not be at the same potential as the mains cord Earth. If it isn't, there will be an AC voltage developed between the two and as a consequence, a current flowing along the 0V connections.
  7. #7
    neazoi's Avatar
    Jan 2008
    Greece
    3,531
    17,477
    32
    Weird, changing the ground point a few CM away in the PCB changes the TX carrier level and hence the modulation.
  8. #8
    Points: 83,988, Level: 70
    Apr 2014
    17,081
    83,988
    70
    Weird? I´m not sure.
    This is why a solid GND plane is that important (Like I very often write in my posts).
    And then one can see that there is a big difference between copper filled layer and a true GND plane layer.
    If you need some support with GND plane: just show us your PCB layout.
  9. #9
    neazoi's Avatar
    Jan 2008
    Greece
    3,531
    17,477
    32
    THIS... is my PCB layout... http://qrp.gr/classic40/
  10. #10
    Apr 2014
    17,081
    83,988
    70
    not that bad.
    Such copper arts usually are much better than any breadboard...or single layer PCB.
  11. #11
    barry's Avatar
    Mar 2005
    California, USA
    4,815
    25,141
    38
    not that bad.
    Yes, but there's also that problematic white protoboard, and another board in the background; are those part of the system?
  12. #12
    neazoi's Avatar
    Jan 2008
    Greece
    3,531
    17,477
    32
    It did not make a difference.
    I notice this hum only when switching the RX to AM. On CW no hum is heard. Does this tell you something?
  13. #13
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    14,045
    85,362
    71
    Only that there is no frequency modulation on the carrier. When receiving in CW mode you probably wouldn't hear very low frequencies because of the receiver audio filtering.
    What happens if you short out the audio input, with and without the audio cables connected?
  14. #14
    neazoi's Avatar
    Jan 2008
    Greece
    3,531
    17,477
    32
    The hum gets louder. But I am touching the shorting metal with my hand...
  15. #15
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    14,045
    85,362
    71
    That suggests you are becoming part of the signal path.
    Can you check that the PSU you are using really has a ground connection. There should be one but I'm thinking if you are using a laptop supply it might have a two pin mains connector and if I'm right, there would be no ground at all on your gadget except through the audio cable.
  16. #16
    neazoi's Avatar
    Jan 2008
    Greece
    3,531
    17,477
    32
    Hm... But I have tested this with the simple linear PSU and also with the LAB psu, which has a ground (the mains ground)
  17. #17
    barry's Avatar
    Mar 2005
    California, USA
    4,815
    25,141
    38
    Quote Originally Posted by neazoi View Post
    Don’t confuse mains ground with the negative supply terminal; they’re generally isolated.it’s the negative terminal(common) that needs attention.
  18. #18
    neazoi's Avatar
    Jan 2008
    Greece
    3,531
    17,477
    32
    Tha LAB PSU has a ground terminal which is bridged with the negative terminal of the PSU. So you can optionally disconnect the GND of the house from the minus pole. I have it connected.
