Verilog with multiple if conditions
techy5025
Orlando, Fla
I am using an if statement with multiple conditionals. Is there a shortcut way to write this as the "year_rt" is the same in each case .. but the condition is different. This is used in a string of "if" statements that doesn't lend itself well to using the "case" statement.
 if ((year_rt == 06) || (year_rt == 17) || (year_rt == 23))
      begin
          calendar <= 1;               // Month starts on Sunday
          leap <= 0;                    // .. no leap year
      end
Thanks,
Jim
You could look for a mathematical formula
Or use a table
case statement is the most compact way to write the multiple comparison:
Code Verilog - [expand]
case (year_rt)
   6, 17, 23:
      begin
      end
 endcase
System Verilog inside operator could be also used, if supported by your tool.
Thanks for the reply's! I am a newby to verilog and am trying to get familiar with the syntax and structure. I thought use of the "case" statement required that the "cases" be sequential .. as in 1,2,3,4. Every example I have seen was like that .. obviously not. I will recode .. and look for the "inside" operator. Lots to learn!
Thanks again,
Jim
calendar <= some value;               // Month starts on Sunday
leap <= some value;                    // .. no leap year
case(year_rt)
    6,17,23:
      begin
      end
endcase
This kind of coding can avoid latch.
