huytergan
Member level 3
I stuck with some questions about 3x3 patch array. It's said that patch antenna frequently is 200 Ohm. Is it always? Ain't that change with antenna design parameters such as length? Do I have to consider each patch is 200 Ohm and design the feed lines in respect to 200 Ohm and at the end of the antenna, transform it to 50 Ohm which's I wanna feed the antenna with?
