CML DFF with Preset port
NikosTS
I was wandering if the traditional CML master-slave D flip flop could be modified in order to include a Set port?
Configure master or slave as OR.
Im using 2 cascaded CML D latches in order to implement the CML D Flip flop. Can you please explain a bit more how to configure the slave e.g as an OR gate?
Show me your schematic.
I or elseone can modify it easily.
This is my schematic. I dont know if you need a better screenshot or you can see it clearly
That's the flattened master-slave configuration. 2 latches cascaded
Which feedback path do you mean? According to the image below, this should be the schematic of a DFF using master-slave latches.
Also, through simulation it seems to behave correctly
I have read this but i dont get anything specific on my original question..
So you mean in the second latch ( slave latch e.g ) , add also input for SET and SETbar in OR configuration?
Or instead of a second latch , use an OR gate?
