Sounds to me like a enhancement P-channel MOSFET/PMOST application.
Source attached to 3.3 V and the Drain to the load. If the Gate voltage is 3.3 V than the PMOST turns off. If the Gate is 0 V, the PMOST is turned on, thus 3.3 V are availabel at the Drain.
This would be a possible solution if the device should be used to switch a power supply. If you are interest in a data-signal, there are other possebilities.
