[SOLVED] HFSS radiation pattern multiple ports
antonovs
Newbie level 3
Can HFSS store multiple radiation pattern (field results) per port.
I have simple microstrip, that can be excited from both ends by wave ports.
Radiation patterns will be different (ok, its very similar, but different direction).
How to tell HFSS what port to use for field calculation?
When I deactivate first-defined excitation in Excitations group, HFSS stops to build radiation patterns.
Solved. I try: Menu: HFSS->Fields->Edit sources.
