asrock70
Full Member level 4
I need a regulated current source 0.1-20A (output power 5W-500W) which will be able to supply current permanently (couple of minutes) , but also pulse with adjustable width and pulse frequency from 100ms.
Pulse operation will be resolved by a transistor output at the control processor.
My idea is use 75V Synchronous Buck Controller With Wide Input Voltage and Duty Cycle Ranges with LM5145, any as this
Input voltage 48V, on output high side current monitor for current feedback and high side ultralow RdsOn MOSFET for pulse operation.
The question is, do you consider it a good idea or am I just getting into trouble?
