Keil code generated by Proteus vs STM32cube
fm101
Member level 5
hi,
i am working with proteus simulation of stm32 microcontroller along with stm32cube which generates C code using keil compiler. attached are screenshots
i wanted to ask why the C code files generated by Proteus for stm32 microcontroller using keil compiler is different from the C code files generated by stm32cube with keil compiler selected....
what i want is to create code from stm32cube and use that code in proteus...but the C code files and files tree are different....how do i use all stm32cube keil generated c files in proteus?import? attached are screenshots
thanks
If you select GCC compiler for both environments you would have some degree of compatibility, I would be surprised if there was no such configuration option on both development platforms.
gcc compiler is another thing..wanted to use keil compiler....the only workaround i see is to import all the files generated by stm32cube which opens keil ide....right?
how to import all files and structure from keil ide to proteus?
hi,
thanks
Hi
There are 2 library for STM32 microcontrollers. The HAL Library and The Standard Library.
The stm32cube use HAL Library. May be proteus is using the standard library
Proteus generated minimum code needed to work. but stmCube inserted the full library.
    nhatpha
hi hamidrezamaddah,
you might be right, i will look into it....thanks
