Results 1 to 5 of 5
    Full Member level 2
    Points: 2,287, Level: 11
    May 2010
    fdsf
    122
    2,287
    11
    Solder msop-8 max temperature ?
    with such small packages, I was wondering what was the max temp to solder these?
    the datasheet says the max temp these chips can handle is 150° but melting tin needs at least 250°
    http://ww1.microchip.com/downloads/e...Doc/21294E.pdf
    thanks for your advices on this
    Points: 266,444, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,566
    266,444
    100
    Re: Solder msop-8 max temperature ?
    150° maxiumum temperature isn't specific to these packages, you'll find similar specs for most semiconductor devices, IC and discretes. They are nevertheless designed for lead-free solder process with necessary temperatures, you find reflow temperature profiles in datasheets and application notes.
    A special problem of very thin packages (smaller than MSOP) is their maximum "floor live" after been taken out of the sealed dry bag. Before reflow soldering, they need baking. Read about MSL https://en.m.wikipedia.org/wiki/Mois...sitivity_level
    Full Member level 2
    May 2010
    fdsf
    122
    2,287
    11
    I dont have any reflow aparatus, just my soldering iron
    there is no MSL nor reflow temperature info in the datasheet
    Points: 83,981, Level: 70
    Apr 2014
    17,075
    83,981
    70
    The manufacturer gives an application note with soldering recommendations.
    (As every manufacturer should do)
    http://www.microchip.com/wwwAppNotes...pnote=en014686
    But you know the package is not designed for iron soldering, thus you may refer to the reflow informations.
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,566
    266,444
    100
    This MSOP package has no exposed pad and can be well soldered with fine soldering iron tip.
