Results 1 to 14 of 14
    Full Member level 1
    Points: 1,757, Level: 9
    Jan 2013
    96
    1,757
    9
    Nonlinear capacitor in Cadence Virtuoso/spectre?
    Fairly trivial question: What is the proper way to model a nonlinear capacitor in Virtuoso?
    In LTSpice, I can just use an expression like this:
    Q=1e-6*x+a*1e-6*0.5*tanh(2*x)
    In Cadence, I tried the following:
    C1 (vout 0) capacitor c=1e-6*(1+0.5*v(vout,0))
    However, first I would need to manually add the node name "vout" into the expression ... which means if I change the name of the output node in Cadence I need to change it in the object properties as well.
    Second, the variable "vout" always lands as a variable in my ADE L window when I start simulation.
    Hence I am not sure this is the right way to do it ...
    Points: 18,280, Level: 32
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,849
    18,280
    32
    Re: Nonlinear capacitor in Cadence Virtuoso/spectre?
    Quote Originally Posted by exp View Post
    in Virtuoso?
    What do you want to mean ?
    In Cadence
    Use correct terminology.
    Understand things correctly.
    If you use Cadence Spectre, use spectre’s primitive “bsource”.
    See “spectre -h bsource”.
    Or use Verilog-A.
    Full Member level 1
    Jan 2013
    96
    1,757
    9
    Thank you, got it working now. In the netlist it looks as you wrote (just with capacitor instead of bsource) ... in ADE L I instantiate a capacitor and write the expression C*(1+b1*v(vout,0)) for capacitor value.
    However, when I start simulation in ADE L it treats "vout" as variable that is filled into ADE L and gives a warning. Simulation still works (I checked the results) but it's pretty annoying and confusing:
    Is there a way to avoid this?
    Oct 2006
    Real Homeless
    2,849
    18,280
    32
    You can not understand Cadence Spectre at all.
    Surely see and undestand bsource.
    Full Member level 1
    Jan 2013
    96
    1,757
    9
    I understand bsource and spectre ... it is working.
    I am talking about an ADE L issue
    Oct 2006
    Real Homeless
    2,849
    18,280
    32
    Don’t rely on ADE.
    Or use netlist fragment include.
    You can never utilize full ability of Cadence Spectre as far as you rely on Cadence ADE.
    I will describe model as three or four terminal device by Verilog-A.
    module aho_cap(pos, neg, ctrl)
    or
    module aho_cap(pos, neg, ctrl, ref)
    BTW, answer my quetions in your nonsense thread.
    https://www.edaboard.com/thread351341.html#9
  7. #7
    Points: 41,401, Level: 49
    Mar 2008
    USA
    6,667
    41,401
    49
    Are you sure that a properly parameterized, native
    diode or MOS capacitor model (with or without a
    companion "bulk cap" for the non-variable part)
    couldn't be fitted up "well enough"? Both are widely
    used as variable (nonlinear) capacitors in RFICs.
  8. #8
    Points: 31,595, Level: 43
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,642
    31,595
    43
    Assign an initial value for "vout" in variables list in ADE.Either enter it manually or automatically import from schematic.Otherwise it won't work as wanted..
  9. #9
    Oct 2006
    Real Homeless
    2,849
    18,280
    32
    Quote Originally Posted by BigBoss View Post
    ”vout” is a node name.
  10. #10
    Advanced Member level 3
    Points: 6,336, Level: 18
    Dominik Przyborowski's Avatar
    Jun 2013
    Norway
    808
    6,336
    18
    Quote Originally Posted by pancho_hideboo View Post
    We don't know it. This statement is based on assumption that our dear friend done everything properly.
    However, I am really unsure about this.
    So, dear exp, show us a netlist and spectre log.
    It might be a bug in ADE L (as I know it is deprecated tool), however it might be not.
  11. #11
    Full Member level 1
    Jan 2013
    96
    1,757
    9
    Quote Originally Posted by dick_freebird
    It will, eventually. But right now I am working with behavioral models and first need to match the behavior of my circuit with hand calculations.
    So yes, right now I need a nonlinear cap where I can set the nonlinear C(V) curve precicely
    Quote Originally Posted by Dominik Przyborowski View Post
    Yes, indeed it is a node name. This the net list:
    // Generated for: spectre
    // Generated on: Apr 14 04:45:04 2020
    // Design library name: test
    // Design cell name: test_nonlinear_cap
    // Design view name: schematic
    simulator lang=spectre
    global 0
    parameters _EXPR_2=9.765625e-10 Pin=-23 vout fin=1M \
        b1=1 C=1n R=1k
    // Library name: test
    // Cell name: test_nonlinear_cap
    // View name: schematic
    C1 (vout 0) capacitor c=C*(1+b1*v(vout,0))
    PORT0 (vout 0) port r=R type=sine freq=fin dbm=Pin-6 fundname="fin"
    simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
        tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
        digits=5 cols=80 pivrel=1e-3 sensfile="../psf/sens.output" \
        checklimitdest=psf
    pss  pss  fund=10k  harms=49  errpreset=conservative
    +    annotate=status  strobeperiod=_EXPR_2
    modelParameter info what=models where=rawfile
    element info what=inst where=rawfile
    outputParameter info what=output where=rawfile
    designParamVals info what=parameters where=rawfile
    primitives info what=primitives where=rawfile
    subckts info what=subckts  where=rawfile
    saveOptions options save=allpub
    As I said, the simulation (in spectre) itself works, I think it is an ADE L issue. It does not realize that it's a nodename and wants to import the variable into ADE L.
    Creating a separate netlist and important sounds like an option, yes, although not ideal.
    I did not expect this to work because I assume "C1 (vout 0) capacitor c=C*(1+b1*v(vout,0))" would be replaced with "C1 (vout 0) capacitor c=C*(1+b1*v(0,0))" which is the same as "C1 (vout 0) capacitor c=C".
    However, I tried just setting vout to some number in ADE L (e.g. 0) and it seems it still works:
    // Generated on: Apr 14 05:00:47 2020
    global 0
    parameters _EXPR_2=9.765625e-10 Pin=-23 vout=0 fin=1M \
        b1=1 C=1n R=1k
        checklimitdest=psf
    This solution is not optimal either (since I have now the bogus "vout" variable in ADE L) but at least the error message is gone.
  12. #12
    Jun 2013
    Norway
    808
    6,336
    18
    It seems that in some cases, netlister treat formula as nested one, and force node name to be a variable to set initial conditions.
    To work around I would try to check following hypothesis/steps:
    1. replace port with a voltage source with defined dc
    2. replace capacitor with charge element (bsource with formula for charge, when dq=c(v)dv) - will need to calculate indefinite integral for charge
    3. define at least initial phase for port signal (maybe explicitly other parameters)
    4. define initial conditions for capacitor (analogLib cap has such parameter)
  13. #13
    Mar 2008
    USA
    6,667
    41,401
    49
    While veriloga has ability to do maths on -results- during
    execution, I don't believe SPICEs or Spectre will do so.
    says to me that (a) function v() would be looked for and
    want a declaration, as a netlist argument, (b) the vout
    argument to the v() function also wants definition as it
    is in a "value" field, not a "connectivity" field of the
    netlist line.
    Have you tried making a veriloga capacitor model?
  14. #14
    Oct 2006
    Real Homeless
    2,849
    18,280
    32
    In Cadence Spectre, resistor, capacitor and inductor which have behavioral expression are actually Spectre's primitive "bsource".
    They are alises for Spectre's primitive "bsource".
    Cadence Spectre did not have an abilty for behavioral expression in resistor, capacitor and inductor.
    On the other hand, Synopsys HSPICE have them from first.
    Many device model files are provides as HSPICE syntax.
    Spectre's primitive "bsource" were introduced for comatibilty with HSPICE netlist, since HSPICE is a golden standard simulator.
    So Spectre's primitive "bsource" are not oriented as instances in schematic.
    Use netlist.
    Or use Verilog-A module instead of bsource.
    "bsource" is actually expressed by Verilog-A in Cadence Spectre.
