Results 1 to 8 of 8
    Newbie level 6
    Points: 687, Level: 5
    Nov 2016
    12
    687
    higher output frequency with PCA9685?
    Hello every one.
    pca9685 has an external clock input pin.
    and its maximum output frequency is about 1.6khz as mentions in the datasheet.
    can we increase the output frequency using a 50MHz crystal oscilator?
    or is there any other way to increse the output frequency?
    i want to make 16, 50khz pwm waveform and control their duty cycles.
    Points: 84,013, Level: 70
    Apr 2014
    17,087
    84,013
    70
    Re: higher output frequency with PCA9685?
    simple calculation:
    50kHz PWM frequency x 4096 (12 bits resolution) = 204,800kHz = about 205MHz input clock.
    Answer: not possible.
    Points: 266,518, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,581
    266,518
    100
    The maximum PWM frequency is actually fclk/(4*4096), there's an additional prescaler.
    Newbie level 6
    Nov 2016
    12
    687
    thank u,
    do you have any other suggestions for producing 16 PWM signal?
    I use Arduino mega 2560 and pca9685 for low frequency. and i know that pca9635 could be used for 96khz PWM.
    but what can I do for 50khz?
    do you know any other PWM ic that could be controlled with a microcontroller?
    Newbie level 6
    Nov 2016
    12
    687
    yes
    its internal clock is 25Mhz and max freq is 1.6khz.
    it seems that "Klaus" calculations are not correct and there's an additional prescaler.
    Apr 2014
    17,087
    84,013
    70
    You may say "not correct"...
    but I did just a general calculation of the required minimum input frequency .. (for any digital PWM generation, not only MAX9685)
    and if the minimum required frequency is 200MHz then I saw no need to do further calculations.
    For sure I can do: 200MHz x 4 (min prescaler) = 800MHz.
    Still above 50MHz, still not possible.
    What PWM resolution do you need?
    Whay exactly 50kHz? What tolerance / range do you allow?
    PCA9955 operates with 31.25kHz... this is the closest on a quick view.
    But any small FPGA will do. What quantity? Maybe you find someone coding and programming it for you.
  7. #7
    Points: 54,851, Level: 57
    Apr 2011
    Minneapolis, Minnesota, USA
    13,361
    54,851
    57
    Quote Originally Posted by omax View Post
    A 555 timer IC is able to produce PWM, by applying a voltage to its control pin #5.
    Low V makes short duty cycle. Higher V makes long duty cycle. Hence PWM. In some degree it's PFM because carrier frequency is unfixed.
    16 timer IC's are needed of course.
  8. #8
    Newbie level 6
    Nov 2016
    12
    687
    your replies are always useful:
    I used two Arduino as master and slave to produce the 16 PWMs with F=31khz. (by modifying some registry codes to get this freq.)
    maybe I start to learn FPGA.
