Results 1 to 3 of 3
    Full Member level 2
    Points: 2,030, Level: 10
    Oct 2012
    137
    2,030
    10
    Generating a digital pulse of 10 secs and 1 sec
    I wanted to know if there are any ways of generating a 10 sec digital pulse (0.1 Hz; 5 sec ON and 5 sec. OFF). I need it as an enable signal for a project I am making (the ckt. will be enabled for 5 secs. to sample the inputs and then disabled for 5 secs. during its processing). Similarly, how to generate a 1 sec. pulse (1 Hz; 0.5 sec. ON and 0.5 secs. OFF). Any pointers will be thankfully acknowledged.
    Thanks and Regards,
    Arvind Gupta.
    Points: 266,396, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,553
    266,396
    100
    Re: Generating a digital pulse of 10 secs and 1 sec
    How about building a digital timer? Can be made in programmable logic, but also using a microcontroller or by assembling discrete logic ICs. All three variants will use a crystal oscillator if precise timing is intended.
    Points: 54,829, Level: 57
    Apr 2011
    Minneapolis, Minnesota, USA
    13,357
    54,829
    57
    Once you have 1 Hz, apply that to a 4017 decade counter. It divides by 10. To have 50 percent duty cycle, combine 5 diodes from 5 consecutive outputs.
    To get 1Hz, is a 555 timer IC good enough? Or else if you need accuracy then start with a crystal oscillator, say 32kHz. Divide down cycles via one or more 4020/ 4040/ 4060 IC.
