Results 1 to 7 of 7
    Member level 3
    Points: 1,005, Level: 7
    HasHx's Avatar
    Oct 2016
    Amman
    63
    1,005
    7
    Solving issues in my PCB grounding
    I am testing a PCB that i have designed, it is a 4-layer design and has various digital components, everything works fine but the issue is that when i touch any GND point i get electrocuted. any idea where this comes from?
    Points: 266,464, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,577
    266,464
    100
    Re: Solving issues in my PCB grounding
    I guess there's no high voltage generated on the board. Hence it's a problem of the power supply. What is it?
    Points: 31,655, Level: 43
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,650
    31,655
    43
    This is likely SMPS problem.It's not dangerous much but should be carefully examined.
    My TV receiver is SONY and when I check the voltage on his chassis with a electrical tester, I see some electrical leakage.But your case is more dangerous thought.
    Member level 3
    HasHx's Avatar
    Oct 2016
    Amman
    63
    1,005
    7
    Thanks for replying to my thread.
    I went over the issue again today and i realized that it could be because of the external power supply I am using, it is: https://product.tdk.com/info/en/cata...ls25-150_e.pdf
    could it be the cause of the problem? because when i turned the device on and sourced power from the battery (which is connected to the boost converter) the problem disappeared.
    Regards.
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,650
    31,655
    43
    TDL Lambda has very good reputation and I believe it has been tested very well before supplied. But every system may have a fault so if the voltage leaking is not shocking level, it may be omitted.
    The best way to measure the current between SMPS chassis and true GND.If there is more than current (mA or better uA level) than specified, it should be replaced.
    Points: 8,815, Level: 22
    Nov 2009
    Italy
    1,196
    8,815
    22
    What about the earthing of your bench ?
  7. #7
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,577
    266,464
    100
    The SMPS is a Class I device, designed to be operated with proper proctective earth connection. The problem description suggests that the PE connection is missing.
