Results 1 to 4 of 4
    Junior Member level 1
    Points: 1,950, Level: 10
    Jan 2010
    17
    1,950
    10
    Enable circuit for backup battery boost converter
    Hi!
    I need to realize backup battery with boost converter in my design.
    To minimize battery current I need to keep boost converter disabled until main power is lost.
    Switching to backup battery should be uninterrupted.
    Main power: 8V
    Battery: 3V
    Boost coverter: 7V
    Could you recommend any cheap and effective way of doing this?
    Advanced Member level 2
    Points: 3,343, Level: 13
    Jan 2019
    613
    3,343
    13
    Re: Enable circuit for backup battery boost converter
    is the enable high or low?
    assuming enable is high, connect two resistors in series from 8V source to ground
    connect the collector of an NPN transistor to enable
    connect base of said transistor to junction of two resistors
    connect emitter to ground.
    when 8 V is present, the transistor will be ON, pulling enable low, boost OFF
    when 8 V is not present, transistor will be OFF, letting enable go high, boost ON
    add a capacitor at SYS to smooth transition
    resistor values not critical
    from 8V to base, about 10k
    from base to ground, about 1K
    transistor - any small signal device useful as a switch, like 2N2222A or 2N3019
    Points: 83,859, Level: 70
    Apr 2014
    17,049
    83,859
    70
    Add two resistors an NPN BJT.
    Two resistors as voltage divider from 8V
    Center of divider to bjt_base
    Bjt emitter to GND
    Bjt collector to Boost_EN
    Jan 2010
    17
    1,950
    10
    Thanks for replies.
    Yes enable is active high.
