We offer brand new and original electronic components at competitive prices. Wholesale and retail are welcome. Mail delivery only (postage is not included). No refunds or exchanges.
Orders or enquiries, please send email to: enquiry@alien-1.com.
Website: www.alien-1.com
FaceBook: https://www.facebook.com/HKAlien1/
Table below only shows part of our stock:
Category Description Unit Price (USD)
Cement Resistor 5 Watt 0.1 Ohm 1.00
Cement Resistor 5 Watt 0.5 Ohm 1.00
Cement Resistor 5 Watt 1 Ohm 1.00
Cement Resistor 5 Watt 8K2 Ohm 1.00
Power Resistor 50 Watt 0.5 Ohm Aluminum Housed Wirewound 7.50
MOSFET RFP50N06 N-Channel MOSFET, 50 A, 60 V MegaFET, 3-Pin TO-220AB ON Semiconductor 1.00
IC Sn76604 DIP-14 BIDIRECTIONAL SERVO-AMP PULSE WIDTH 1.00
IC NE556 Dual Timer DIP-14 0.40
Relay RAL9W-K TAKAMISAWA Power Relay 9V 1.50
Relay RA9W-K TAKAMISAWA Power Relay 9V SPDT relay 1.50
Relay RA12W-K TAKAMISAWA POWER CUBE RELAY 8-PIN 0.013A (Coil), 12VDC (Coil) 1.50
Relay TAKAMISAWA Power Relay 9V SPDT relay 1.50
Relay TAKAMISAWA SZ-12W micro relay 2.00
Relay KAM LING KU1T-B 5V relay SPDT RES. Load 5A, 110VAC or 24 VDC, Coil DC 5V 1.50
Relay OMRON SPDT 9V Relay G5L-114P-PS 1.50
Relay OMRON SPDT 9V Relay G2E-184P-M-US 1.50
Relay Matsushita DS2Y-S-DC9V relay 1.50
Relay FUJITSU 244N-D012/02CS 2A, 12V 1.50
Reed Switch OEG OMR-H 500 ohm reed relay switch SPST 0.50
Mini Meter 5K Ohm /V Mini Meter 0.60
Condenser Mic HOSIDEN Electret Condenser Mic ~9.5mm (diameter) x 6.5mm (height) 0.60
Condenser Mic 博捷 Condenser Mic ~6mm (diameter) x 3mm (height) 0.30
Condenser Mic Condenser Mic ~6mm (diameter) x 3mm (height) 0.30
Condenser Mic HOSIDEN Electret Condenser Mic ~10mm (diameter) x 5mm (height) KUC3723-040245 0.60
Condenser Mic Condenser Mic ~10mm (diameter) x 7mm (height) 0.30
Condenser Mic Condenser Mic ~9.7mm (diameter) x 4.5mm (height) 0.30
Power Socket NICOON Screw Mount Power Socket 250V 6A 1.00
DIN Plug 5p DIN plug plastic 180° (5 Pin) 2.00
Crystal Socket Radio Scanner Crystal Sockets for HC-25/U HC-49U HK-49/T HC-50/U 0.50
Fuse Holder Fuse Holder Case for 5x20mm Glass Tube Fuses 10A 0.60
Transistor NEC JE9018 NPN Transistor for RF TO-92 0.40
Transistor HITACHI 9015 PNP Transistor TO-92 0.40
Transistor 2SK1491 NEC Transistor TO-3P 4.00
Transistor BF410C Transistor TO-92 2.00
Transistor MJE521 Motorola NPN Transistor 1.50
Transistor 2SC4242 NPN Transistor TO-220 3.00
Transistor NEC 2SB772 PNP Transistor TO-126 0.15
Bridge Rectifier W10 Bridge Rectifier 5A 1000V 0.30
Bridge Rectifier Bridge Rectifier KBL06 0.60
Bridge Rectifier Bridge Rectifier KBL406 0.60
Bridge Rectifier KBPC5010 Bridge Rectifier 50A 1000V 2.00
