Results 1 to 5 of 5
    Newbie level 3
    Points: 2,034, Level: 10
    Apr 2009
    2,034
    10
    Is a snubber circuit required with zero-cross optocoupler
    I am a newbie to power electronics but can understand the basics. My very specific question is, whether a snubber circuit is needed for a triac that is driven by an optocoupler that is based on zero-crossing, like MOC3043?
    Points: 25,137, Level: 38
    barry's Avatar
    Mar 2005
    California, USA
    4,814
    25,137
    38
    Re: Is a snubber circuit required with zero-cross optocoupler
    I think it depends on the application. If you've got an inductive load, where current and voltage are 90 degrees out of phase, you might still need a snubber.
    Newbie level 3
    Apr 2009
    2,034
    10
    Quote Originally Posted by barry View Post
    Hi Barry, thank you for response. So, if I understood you correctly, since it is zero cross voltage, current might still not be zero which can cause undesirable effect. in this case, what type of capacitor is ideal. should I go for capacitors at some rated AC voltage of like 275VAC or a smaller one will do as we only deal with current?
    Points: 14,022, Level: 28
    Aug 2015
    Melbourne
    2,301
    14,022
    28
    A snubber is a good idea if the load is unknown, these drivers switch the triac on soon after zero crossing, so the load current will start from zero too ( although will go up quickly for some loads ) when the opto led drive is removed the triac will turn off as the load current goes through zero - as long as the re-applied dv/dt does not trigger it back on - some inductive or motor loads can provide a back emf which can trigger the triac back on - the snubber is to prevent this ... ( the dv/dt at turn off being too high )
    Points: 266,359, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,544
    266,359
    100
    I experienced a case where a MOC3040 plus triac combination was periodically self triggered even with pure resistive load by power supply dV/dt. A 220 ohm/47 nF snubber and filter was added to the MOC3040 circuit.
