kahlenberg
Junior Member level 3
I have a Samsung GT-P5210 10.1 inch Tablet and it doesn't work. It doesn't charge and it doesn't switch on.
I tried following:
Reset it by pressing power and volum up OR down button simultaneously, it didn't show anything.
Leave it connected to charger more than one day. It didn't show anything.
I measured battery voltage, It shows 2.3V, yes it ist not good, but even without battery and plugged to charger, it doesn't show anything.
I connected it to Ubuntu laptop with USB cable, dmesg in Ubuntu shows some messages:
usb1-2: Manufacturer: Intel
usb1-2: SerialNumber: XXX
I measure the voltage and current on micro USB input.
It draws ~20mA less than 1s and then it stops drawing current.
I think there must be some short circuits but could not locate it.
But even if there is a short circuit, then USB functionality should also not work, laptop shows some messages if connected.
What can the problem be?
Can I repair it?
Thanks.
I tried following:
Can I repair it?
Thanks.
