Results 1 to 3 of 3
    Advanced Member level 1
    Points: 4,482, Level: 15
    Jul 2006
    USA
    416
    4,482
    15
    bipolar active linear region
    The bipolar active linear (amplification) region is defined as Vbe>0 and Vbc<0, and the saturation region is defined as Vbe>0, and Vbc>0. Note that this is bipolar, the saturation region of bipolar with similar with the linear region of cmos.
    In my simulation, Vbe=0.75V, I sweep the Vce from 0 to 2V, and I found that the collector current becomes almost constant when Vce is larger than 0.3V. We can say that when Vce is larger than 0.3V, BJT is in active linear region.
    The confusion is that in definition, for the active linear region, the definition requires Vbc<0. However, in my simulation, Vbc=0.7-0.3=0.4V >0, and BJT enters the active linear region. Why? Can you please explain?
    Points: 31,638, Level: 43
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,648
    31,638
    43
    Re: bipolar active linear region
    Your definition Vbc<0 is not correct.
    Exact statement should be B-C junction is reverse biased for Linear region,Forward biased for Saturation Region.
    So B-C junction is forward biased whilst the Vbc>0.x V.
    Points: 41,419, Level: 49
    Mar 2008
    USA
    6,673
    41,419
    49
    The definition is arbitrary and does not comprehend
    that the "saturation region" is a continuum of declining
    hFE and Rc, both, as Vce approaches zero.
    Check out the relation of "forced beta" to "Vce(sat)"
    and see that current gain persists well into saturation.
