[SOLVED] Steady state power system design
MD_SHAHRUKH
Bangalore, India
Hello everyone.
I have designed two power supply circuit, which is below.
these two power supply is generated using 12V.
I need to know the time to reach the steady-state voltage. Do i need to calculate the RC filter. And if so what value of output resistance should i consider? and I need this because I need to avoid the sneak paths. my system contains few voltage level shifters.
can you suggest me the exact calculation I need to do.
Thank you.
I'd consult the datasheet.
And if it does not give the expected information I'd start a simulation.
You may also build the circuit and use a scope.
Which R and which C are you talking about?
Klaus
There's no relevant RC time constant in your circuit. Why don't you simply refer to the start-up waveform in TPS56220 datasheet? Optionally PSpice transient model?
