Results 1 to 5 of 5
    Junior Member level 2
    Points: 765, Level: 6
    Nov 2016
    ShengXiaLu
    20
    765
    How to estimate power consumption at the IP design level?
    description:
    In the IP design stage, sometimes there is no actual foundry-library to test IP performance, so will use similar foundry-library (or even any foundry-library) for testing.
    IP test points are: highest frequency, area, power consumption.
    As for area, we can use '2-input-NAND' as the unit area, and calculate the gate-count for the area estimate.
    problem:
    As for the power consumption, is there any quantity as the unit for power consumption, and thus there is a quantity for power consumption estimating?
    Points: 2,275, Level: 11
    Jun 2008
    22
    2,275
    11
    Re: How to estimate power consumption at the IP design level?
    RTL level: Using tools, such as spyglass power, joulus
    Gate level: Using tools, PTPX
    Points: 9,412, Level: 23
    Apr 2016
    1,956
    9,412
    23
    I don't understand the question. The unit utilised for power is W, there is no need for a proxy for power.
    Really, I am not Sam.
    Advanced Member level 1
    Points: 5,754, Level: 18
    May 2005
    462
    5,754
    18
    If you know roughly how frequently FFs and gates toggle for a particular design, you can multiply that factor by the number of gates times the power consumption for the average gate, for a very coarse estimate. But it's very easy to be orders of magnitude out.
    Nov 2016
    ShengXiaLu
    20
    765
    Thanks a lot. gates toggle can be as a quantity for power coarse calculate.
    'W' is an absolutely unit. I want to find a relative unit.
