Results 1 to 2 of 2
    Newbie level 5
    Points: 638, Level: 5
    Jan 2017
    9
    638
    How to check recevied power in the HFSS port?
    Hi!
    I'm simulating a 4*1 receiver antenna array in HFSS. I want to check the antenna performance in the receiving mode. Now I put a plane wave source in the antenna array's far-field. I can observe received E-field and H-field in the substrate moving into the port. But I don't know how to obtain the received power and phase in the port? Can anyone help me on this? Thanks!
    Points: 15,166, Level: 29
    Apr 2014
    2,357
    15,166
    29
    Re: How to check recevied power in the HFSS port?
    This sounds like the wrong workflow. Because of reciprocity, you can test the transmit case, which is much easier.
