Problem implementing project in ISE 14.5 using ipcore fifo_generator 9.3
Cesar0182
Member level 5
Greetings ... comment that I am with a small project in ISE 14.5, I have managed to synthesize but I am having compatibility problems with the ipcore fifo_generator 9.3 when implementing and I am having one of the errors.
ERROR:NgdBuild:604 - logical block 'u_client[0].U_client_ff' with type
   'g1_ipcat_wbus_client_fifo' could not be resolved. A pin name misspelling can
   cause this, a missing edif or ngc file, case mismatch between the block name
   and the edif or ngc file name, or the misspelling of a type name. Symbol
   'g1_ipcat_wbus_client_fifo' is not supported in target 'virtex5'.
The project is for a Virtex5 device (xc5vlx155t-3ff1136) and the code I am using is the following:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
use IEEE.std_logic_unsigned.all;
USE ieee.std_logic_misc.all;
entity g1_wbus_client_fifos_vhdl is
  Port (
    -- Clock and reset
    i_aur_clk      : IN std_logic;	                    -- Aurora fabric clock
    i_rst          : IN std_logic;                      -- General async reset
    -- wbus stack interface
    o_wbus_ready   : OUT std_logic;
    i_wbus_wen     : IN std_logic;                      -- wbus write enable
    i_wbus_addr    : IN std_logic_vector(31 DOWNTO 0);  -- wbus write address
    i_wbus_data    : IN std_logic_vector(31 DOWNTO 0);  -- wbus write data
    -- 26 Client Channels
    i_wbus_enable  : IN std_logic_vector(25 DOWNTO 0);  -- Allow writes to wbus fifo
    i_wbus_fws     : IN std_logic_vector(129 DOWNTO 0); -- 5-bit FIFO window select for each channel
    i_wbus_clk     : IN std_logic_vector(25 DOWNTO 0);  -- Client clock
    o_wbus_empty   : OUT std_logic_vector(25 DOWNTO 0); -- fifo empty
    i_wbus_ren     : IN std_logic_vector(25 DOWNTO 0);  -- Fifo read enable
    o_wbus_count   : OUT std_logic_vector(259 DOWNTO 0);-- Available data words 10 bits
    --o_wbus_valid   : OUT std_logic_vector(25 DOWNTO 0); -- Address and Data valid
    o_wbus_wdata   : OUT std_logic_vector(831 DOWNTO 0);-- Write Data 32 bits each
    o_wbus_waddr   : OUT std_logic_vector(831 DOWNTO 0);-- Write Address 19 bits valid
    -- Status and Test Points
    o_ro_wbus_debug : OUT std_logic_vector(31 DOWNTO 0);-- Output status bits for a debug register
    o_test_points  : OUT std_logic_vector(3 DOWNTO 0)   -- test points
end g1_wbus_client_fifos_vhdl;
architecture Behavioral of g1_wbus_client_fifos_vhdl is
Component g1_ipcat_wbus_client_fifo
  port(
    rst           : in std_logic;
    wr_clk        : in std_logic;
    din           : in std_logic_vector(51 downto 0);
    wr_en         : in std_logic;
    full          : out std_logic;
    wr_data_count : out std_logic_vector(9 downto 0);
    -- The Client Port is connected to all the read signals
    rd_clk        : in std_logic;
    rd_en         : in std_logic;
    dout          : out std_logic_vector(51 downto 0);
    empty         : out std_logic;
    rd_data_count : out std_logic_vector(9 downto 0)
    --valid         : out std_logic
end component;
CONSTANT Almost_Full_Depth : std_logic_vector(9 downto 0) := "0111110100";
type  wbus_count_type is array(0 to 25) of std_logic_vector(9 downto 0);
type  array_26x10 is array(0 to 25) of std_logic_vector(9 downto 0);
type  array_26x52 is array(0 to 25) of std_logic_vector(51 downto 0);
SIGNAL almost_full      : std_logic_vector(25 DOWNTO 0);
SIGNAL ffdin            : std_logic_vector(51 DOWNTO 0);
SIGNAL ff_dout          : array_26x52;
SIGNAL ff_write_count   : array_26x10;
SIGNAL wbus_count       : wbus_count_type;
SIGNAL wbr_d            : std_logic;
SIGNAL upper_adrs_match : std_logic;
SIGNAL wen              : std_logic_vector(25 downto 0);
SIGNAL almost_full_d    : std_logic_vector(25 downto 0);
SIGNAL wbus_addr_fws    : std_logic_vector(25 downto 0);
begin
-- A fifo is implemented for each client port.
ffdin <= i_wbus_addr(19 downto 0) & i_wbus_data(31 downto 0);
-- Note: Software must monitor the level of each FIFO is some way in order to prevent
-- Almost_Full_Depth from being reached.
u_client : for idx in 0 to 25 generate
  begin
    o_wbus_count(10*idx+9 downto 10*idx)    <= wbus_count(idx); -- Convert from 2D to 1D vector.
    -- Uppermost 2 bits of 8MB Auter space must be 0's
    upper_adrs_match                        <= '1';
    -- Write only one fifo by decoding 5 address bits.
    wbus_addr_fws(idx)  <= '1' when (i_wbus_addr(20 downto 16) = i_wbus_fws(5*idx+4 downto 5*idx)) else '0';
    wen(idx)            <= i_wbus_enable(idx) and i_wbus_wen and upper_adrs_match and wbus_addr_fws(idx);
    almost_full_d(idx)  <= i_wbus_enable(idx) and '1' when (ff_write_count(idx) > Almost_Full_Depth) else '0';
    -- partslib_pkg.vhd: Simple DFF with Clock enable e.
    dc_amf: entity work.dreg_clr_vhdl generic map(1)
      port map(
        c   => i_aur_clk,
        ar  => i_rst,
        e   =>  '1',
        d(0)   => almost_full_d(idx),
        q(0)   => almost_full(idx)
    -- 52 bits x 512, First Word Fall Through.
    U_client_ff: g1_ipcat_wbus_client_fifo
      port map(
        rst           => i_rst,              -- input rst
        wr_clk        => i_aur_clk,          -- input wr_clk
        din           => ffdin,              -- input [51 : 0] din
        wr_en         => wen(idx),           -- input wr_en
        full          => open,               -- output full
        wr_data_count => ff_write_count(idx),-- output [9 : 0] wr_data_count
        rd_clk        => i_wbus_clk(idx),    -- input rd_clk
        rd_en         => i_wbus_ren(idx),    -- input rd_en
        dout          => ff_dout(idx),       -- output [51 : 0] dout
        empty         => o_wbus_empty(idx),  -- output empty
        rd_data_count => wbus_count(idx)    -- output [9 : 0] rd_data_count
        --valid         => o_wbus_valid(idx)   -- output valid
    -- o_wbus_waddr is divided into 32 bit widths for convenience
    -- even though only the lowest 19 bits are used.
    o_wbus_waddr(32*idx+31 downto 32*idx)   <= "0000000000000" & ff_dout(idx)(50 downto 32);
    o_wbus_wdata(32*idx+31 downto 32*idx)   <= ff_dout(idx)(31 downto 0);
end generate u_client;
wbr_d <= NOT OR_REDUCE (almost_full);
dc_wbr : entity work.dreg_clr_vhdl generic map(1)
  PORT MAP (
    c    => i_aur_clk,
    ar   => i_rst,
    e    => '1',
    d(0) => wbr_d,
    q(0) => o_wbus_ready);
-- This output port is for a diagnostic register to read back the 'almost_full' flag of each client fifo.
o_ro_wbus_debug <= X"E" & "00" & almost_full(25 DOWNTO 0); --The '0xE' in the msb nibble is just for
                                                           -- identifying purposes.
o_test_points <= x"0";
end Behavioral;
I leave attached the ipcore fifo_generator, any help is welcome. Thanks in advance.
  • g1_ipcat_wbus_client_fifo.rar
That errors looks like the kind you get when you don't include the core in your design.
As this is ISE I was expecting to see an XCI file in the directory, but there isn't one, that is normally what I always added to my ISE project for an IP core from coregen.
thanks for the help ads-ee ... tell you that ISE coregen creates the XCO file, which I could add to my project and solve that error with ipcore, but now I am having a similar error in another module when using the unisim library.
   'U_pim1_vhdl/U_g1_applic_top_vhdl/U_g1_hotlink_pim_vhdl/HL_TXCLK[1].u_iodelay
   _txclk' with type 'ODELAYE2' could not be resolved. A pin name misspelling
   can cause this, a missing edif or ngc file, case mismatch between the block
   name and the edif or ngc file name, or the misspelling of a type name. Symbol
   'ODELAYE2' is not supported in target 'virtex5'.
Unisim is not used to implement a design, so I'm not sure why you think unisim is causing the NgdBuild error.
From the Virtex5 library guide ODELAYE2 is not a Virtex 5 primitive, it turns out it is a primitive from Virtex7. I'm not sure how you are doing your design but you seem to be mixing different families.
the truth is that the project was done in Vivado 2017.3 for a virtex-7 and I am trying to adapt it for a virtex-5, but I am a novice in ISE. I just saw the Virtex-5 FPGA User Guide datasheet (p. 370) https://www.xilinx.com/support/documentation/user_guides/ug190.pdf and was able to verify that there is an equivalent primitives for ODELAYE2 and OSERDESE2 (OSERDES and IODELAY) for Virtex-5, but the problem is that OSERDES only has 6 inputs parallel data and I require 8. Any suggestions with this problem?
Not equivalent, just a similar type of function You will have to redesign, both the SERDES block implementation and the interface to the FPGA logic.
Generally if you need to port to a new family you have to generate new cores that fit the architecture of the family. If it's something like instantiated IO primitives (i.e. like the OSERDES), then you need to determine how the interface signaling was done on the original design and create a new design that handles the same signalling. The internal FPGA logic interface will be different between families, so you will have to redesign that logic to support the family you are porting to.
