Results 1 to 8 of 8
    Points: 683, Level: 5
    Apr 2018
    50
    683
    Adding '1' to a std_logic_vector in VHDL
    I'm having an error about adding 1 to a std_logic_vector in VHDl.
    Here's the code: It's a 74LS163 Synchronous Binary Counter code.
    LIBRARY ieee;
    USE ieee.std_logic_1164.ALL;
    USE ieee.numeric_std.ALL;
    entity AAC2M2P1 is port (
       CP: 	in std_logic; 	-- clock
       SR:  in std_logic;  -- Active low, synchronous reset
       P:    in std_logic_vector(3 downto 0);  -- Parallel input
       PE:   in std_logic;  -- Parallel Enable (Load)
       CEP: in std_logic;  -- Count enable parallel input
       CET:  in std_logic; -- Count enable trickle input
       Q:   out std_logic_vector(3 downto 0);
        TC:  out std_logic  -- Terminal Count
    end AAC2M2P1;
    architecture LS163 of AAC2M2P1 is
    signal temp: std_logic_vector(0 to 3);
    signal RCO: std_logic;
    	begin process(CP, SR, PE)
    		begin
    			if 	(SR = '1') then
    			temp <= "0000";
    			elsif (rising_edge(CP)) then
    				if (PE = '0') then
    					temp <= P;
    					if (temp = "1111") then
    					temp <= "0000";
    					RCO <= '1';
    					else
    					temp <= temp + 1;  --ERROR
    					RCO <= '0';
    					end if;
    				end if;
    			end if;
    		end process;
    	Q <= temp;
    	TC <= RCO;
    	end LS163;
    I used 1076-2008 in ModelSim - Altera, as "temp <= temp + 1" should be synthesizable but it still got an error when simulated -- No feasible entries for inflix operator '+'.
    I tried using x"1", x"0001" and '1' but all of these didn't worked.
    Also, how should I write the code for using CEP and CET as count enables.
    Member level 4
    Points: 915, Level: 6
    Jun 2017
    near the sea
    73
    915
    Re: Adding '1' to a std_logic_vector in VHDL
    Make temp unsigned, then you can perform arithmetic on it.
    When you output it to Q, cast it as std_logic_vector
    Points: 32,398, Level: 43
    ads-ee's Avatar
    Sep 2013
    USA
    7,489
    32,398
    43
    Quote Originally Posted by chandlerbing65nm View Post
    adding std_logic_vectors is not supported in the numeric_std library as fourtytwo suggests use unsigned which does support arithmetic operations.
    Code VHDL - [expand]
    8
    process(clk)
    begin
      if rising_edge(clk) then
        if (CEP = '1') then   -- counts when high
          CEP_enabled_counter <= CEP_enabled_counter + 1;
        end if;
      end if;
    end process;
    Points: 38,490, Level: 47
    Jun 2010
    6,960
    38,490
    47
    Or use VHDL 2008. The numeric_std_unsigned package allows unsigned arithmatic on std_logic_vector, even allowing the perenial student compilation error - adding a std_logic to a std_logic_vector
    8
    9
    10
    use ieee.numeric_std_unsigned.all;
    signal cnt : std_logic_vector(15 downto 0);
    process(clk)
    begin
      if rising_edge(clk)
        cnt <= cnt + '1';
      end if;
    end process;
    Apr 2018
    50
    683
    I got this final code:
    signal temp: unsigned(3 downto 0);
    signal count_enables: std_logic;
    	begin
    	count_enables <= CEP and CET;
    		process(CP, SR, PE, P) begin
    			if 	(SR = '0') then
    			temp <= "0000";
    				if (PE = '1') then
    					temp <= unsigned(P);
    					if count_enables = '1' then
    						RCO <= '1';
    						temp <= "0000";
    						else
    						RCO <= '0';
    						temp <= temp + 1;
    						end if;
    					end if;
    				end if;
    			end if;
    		end process;
    	Q <= std_logic_vector(temp);
    	TC <= RCO;
    	end LS163;
    and this is the waveform from ModelSim - Altera:
    But the auto grader scored it 5/10 (at online course), (It count up until F for a given time period though). It must be that some of the functions of 74LS163 is not used or misused. If someone could look ever what I'm missing, that will be helpful. Thanks
    Points: 7,907, Level: 21
    Jul 2010
    Sweden
    1,061
    7,907
    21
    The TC output is wrong, should be '1' when the counter is "1111" and CET = '1'.
    The parallel load is wrong, should happen when PE = '0', regardless of CEP and CET.
    An unsigned signal will wrap automatically from "1111" to "0000", so you don't need code for that.
  7. #7
    Apr 2018
    50
    683
    I got the right answer with 1 error in TC. Scored 9/10 but still curious what is the error in TC.
    Here's the updated code.
    	begin
    		counter: process(CP) begin
    			if 	rising_edge(CP) then
    				if SR = '0' then
    				temp <= "0000";
    				elsif SR = '1' and PE = '0' then
    				elsif SR = '1' and PE = '1' and count_enables = '1' then
    				temp <= temp + 1;
    				end if;
    			end if;
    		end process counter;
    		carry: process(P, CET) begin
    			if CET = '1' then
    				RCO <= P(0) and P(1) and P(2) and P(3);
    			else
    				RCO <= '0';
    			end if;
    		end process carry;
    		TC <= RCO;
    	end LS163;
    Here's the waveform in ModelSim.
  8. #8
    Points: 265,394, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,367
    265,394
    100
    RCO is evaluating P input but should evaluate temp respectively Q.
