Results 1 to 6 of 6
    Points: 6,208, Level: 18
    Jan 2012
    Italy
    1,099
    6,208
    18
    Differential comparator with reference comparison voltage level
    Dear friends,
    I am interesting in this circuit of comparator, as you see it has three inputs, the comparator compare both inputs to a reference voltage and based on the comparesion it generates either 0 or 1 , I never had a chance to deal with three input comparator, may be it looks near to common mode feedback circuit but the later one is analog,
    can you please refer me to some material about this circuit so I can design it
    below a part of the comparator description by the author
    and if you like to have more details this is the paper link
    https://ieeexplore.ieee.org/document/7987597
    Thank you in advance
    Advanced Member level 2
    Points: 3,150, Level: 13
    Jan 2019
    574
    3,150
    13
    Re: Differential comparator with reference comparison voltage level
    i'm going with it is a window comparator built from 2 comparators
    like
    http://www.ti.com/lit/ug/tidub01/tidub01.pdf
    not 1 comparator with three inputs
    Full Member level 4
    Points: 1,626, Level: 9
    Jan 2019
    Ireland
    223
    1,626
    9
    Quote Originally Posted by Junus2012 View Post
    If it was a common mode feedback circuit, it would have compared (voutp+voutm)/2 with VR. From the description by the author it seems like it compares (voutp-voutm) to VR.
    To implement this, you would need a difference circuit (ref: http://www.learningaboutelectronics....er-circuit.php) followed by a comparator.
    Points: 265,369, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,364
    265,369
    100
    I have presently no access to IEEE, thus I can't review the paper.
    Basically it's a simple function: comp = sign(Voutp-Voutm-Vr)
    I can imagine many different implementations depending on the available technology and design requirements, thus I don't see much sense in putting the question in such a general way. I presume the paper describes an implementation, what's unclear about it?
    Full Member level 4
    Jan 2019
    Ireland
    223
    1,626
    9
    The paper references to Razavi's textbook for the comparator xD
    Jan 2012
    Italy
    1,099
    6,208
    18
    Dear friends
    Thank you you for your reply
    The author didn't give a descreption about the paper nor any citation about it from different people, the author referred to Behzad Rezavi book but not specifically for this circuit. For some reasons the author didn't show the details of this circuit.
    And one important interesting thing, the author is trying to adjust calibrate the offset of the main amplier by using this comparator, but what about if this comparator has an offset ? may be the comparator has an offset worse than the main amplifier itself
    Could you please refer me to at least one of these possible solutions ? I am using CMOS 0.35 µm technology,
    Quote Originally Posted by vivekroy View Post
    Thank you for your answer,
    it makes sense, but right now I am thinking how big the circuit will be, and as I have commmented before, of the added amplifier has an offset it will be added to the main amplifer
