eagle1109
Full Member level 6
- Joined
- Nov 20, 2014
- Messages
- 390
- Helped
- 4
- Reputation
- 10
- Reaction score
- 7
- Trophy points
- 1,298
- Location
- Saudi Arabia
- Activity points
- 5,929
I modified the circuit a bit.
1. Measuring the signal at the gate, is negative with one scope probe. Why ?
My understanding here, is that the AC has two branches to run in. Path 1 is the path that has the scr, path 2 is the one runs down the pot to the capacitor. So the signal which is I2 should be positive one. Or what exactly ?
a) During the +ve signal, path 1 scr is off so I1 won't run, path 2 the voltage is -18V on oscilloscope and 13V rms, but I2 should be positive.
b) During the -ve signal, path 1 scr is in reverse bias so no current flow, path 2 is also a possible path for the -ve current but I don't know if it's blocked by the capacitor assuming it's an electrolytic one.
So I think I should get both the +ve / -ve pulses, but I only get a negative one ! And I don't know which one is appearing on the scope.
2. The scr doesn't conduct when the pot is at 1% which is 10k ohms + 1k ==> Ig = 220V / 11k ohms = 20mA. That's also shown on the AC multimeter. Also another interesting thing is that I guess the values are in rms.
It's good that I could calculate the gate current thanks Mr Klaus
OK, I did the same trick of combining two scope signals and get the invert of that signal of the gate voltage and put a pot on the gate to get the exact gate current easily.
But this scr gets triggered at 50mA and I measured the voltage signal at the gate in this picture and divided the voltage which is 76V on the actual resistance which is adjusted at 500 ohms and the current was 152mA but the scr didn't get triggered.
Could anyone tell me why ?
