Results 1 to 4 of 4
    Junior Member level 2
    Points: 951, Level: 7
    Aug 2015
    21
    951
    7
    Considering the power amplifier for complex modulate signal
    Dear all,
    I'm choosing a 1W power amplifier for QAM 256, 20MHz bandwidth signal.
    as far I know, the QAM256. 20MHz signal is such like the below.
    the the total power of 20mhz signal is 1W=30dbm, the power of a 1HZ bandwidth signal is 30-10log(20*10^6)= -43dbm. besides, the PAR of 256QAM ~ 7-> the peak power of a signal is -36dbm.
    so, I just need a power amplifier which can stand only -36dbm (may be need some more back-off). Did I wrong ?
    Newbie level 6
    Points: 114, Level: 1
    Dec 2019
    11
    114
    Re: Considering the power amplifier for complex modulate signal
    Peak power of a signal isn't -36 dBm. Its rather -36dBm/Hz which is power spectral density. First you must define peak power of your signal to properly fit amplifier.
    Marcin
    Newbie level 1
    Points: 13, Level: 1
    Mar 2020
    13
    Are there any guidelines on how to define the peak power of the signal properly?
    Hi!
    Points: 265,394, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,372
    265,394
    100
    Crest factor of different QAM signals can be easily found in literature, just ask Google. It's 4.23 dB for 256QAM, means you need at least 2.7 W amplifier peak power for 1 W average. I presume it's a single carrier signal.
