Controller Area Network (CAN) test code
NewbeeAVR
Junior Member level 2
I had created a simple test code for CAN using PIC18F4580. Which consists of 2 nodes sending data between each other. Uses 11-bit standard ID for communication. Node-1 is given ID of 10 and Node-2 is given ID of 20. I tried to display the registers like COMSTAT, TXB0CON, TXERRCNT, RXB0CON, RXERRCN on the LCD. A pull-up key is interfaced to RC3 on both the nodes.
  • When key is pressed it will first show the contents of COMSTAT, TXB0CON, TXERRCNT, RXB0CON, RXERRCNT on LCD in sequence.
  • Then at the end it will put the message frame with ID = XX, DLC = 3, Data = NDx on CAN Bus
  • Node-1 puts ND2 on data field D0(N), D1(D) and D2(2) with DLC is 3 and ID = 20.
  • Similarly Node-2 puts ND1 on data field D0(N), D1(D) and D2(1) with DLC is 3 and ID = 10 (Please refer the Test code given).
Both the nodes are sending and receiving data but the data is some junk than what is expected. I have attached a picture of the same. What may be the problem?
View attachment CANTest.zip
