Results 1 to 4 of 4
    Advanced Member level 3
    Points: 4,460, Level: 15
    Created Album pictures Created Blog entry 7 years registered
    Aug 2011
    728
    4,460
    15
    Blog Entries
    Designing IGBT DC Source
    I need to design an IGBT based dc powersupply for electrochemical application
    Planned to making high current(500A), low ripple and high frequency
    Can we just rectify and change the voltage by PWM?
    Any starting material to start the design with?
    Points: 266,384, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,549
    266,384
    100
    Re: Designing IGBT DC Source
    You didn't specify the output voltage respectively power.
    I presume it's low voltage output, it needs a transformer for acceptable efficiency, either 50 Hz or mid-frequency (kHz range). Isolation might be required for safety reasons anyway.
    Aug 2011
    728
    4,460
    15
    Blog Entries
    Sorry, its 6 to 12V, power will be 0-500A x 6-12V, so power will be around 3kW to 6kW
    Ok, I will work on it and update
    Points: 14,039, Level: 28
    Aug 2015
    Melbourne
    2,306
    14,039
    28
    Hi there, we have done 20kHz switch-modes off 3 phase mains to give 600A at 10VDC, it is not too hard as 565V ( 3 phase rectified bus ) means switching only 12A in the IGBT's - the trick is to have several transformers in series / parallel to make it easier to get the 500A ( in your case ) out
    this also helps spread the heat - feel free to PM me for more tips
