Results 1 to 7 of 7
    Points: 33, Level: 1
    Mar 2020
    Orlando, Fla
    33
    Verilog alarm clock time advancing not working correctly ..
    Hello. I am new to verilog and to this forum, and have been trying to get an alarm clock working on the BASYS 3 FPGA board using Vivado 2019. All the code is working correctly except for the part that advances the time. The problem is that both the seconds and minutes advance together .. so essentially the seconds display as minutes and the minutes as hours. I have included a code snippet below.
    The input clock is at a .1 sec rate. The first part of the code is used to set the min and sec and works correctly. The second part causes the decimal point of the 7-segment display and an LED to blink at a one second rate and also works correctly. The third part steps the second and minutes together. I have tried using blocking and non-blocking code (as here) with the same results. The problem has been verified both on the Vivado simulator and on the BASYS board.
    I'll be happy to be embarrassed by what is obviously a newly mistake!
    Thanks for the help. Jim
     /************* Clock operation**************/
    always @(posedge first_toggle)  //toggle every .1 sec
    begin
           if (reset)
                   begin                // reset counters
                     tmp_chour = 4'b0000;
                     tmp_cmin  = 4'b0000;
                     tmp_csec  = 4'b0000;
                   end
    //set alarm/clock min
            if (set_min)        // set  minutes
                 begin
                     if ((min_del == 0) || (min_del >= 15 ))  // first toggle on key press or 1.5 sec delay
                           begin
                              if (set_alarm)              // Set alarm ?
                                  if(tmp_amin >= 59)      // Min >= 59 ?
                                      tmp_amin = 0;       // Yes - Zero alarm min
                                  else
                                      tmp_amin = tmp_amin + 1; //No - bump alarm min
                              else if(tmp_cmin >= 59)     // Min >= 59 ?
                                      tmp_cmin = 0;       // Yes - Zero clock min
                                   else
                                      tmp_cmin = tmp_cmin + 1; //No - bump clock min
                              if (min_del <= 14)          // 1.5 sec delay for fast speed
                                  min_del <= min_del +1;  // Bump delay tenths of a sec
                           end
                     else if (min_del <= 14)              // 1.5 sec delay for fast speed
                  end
             else
                  min_del = 0; // Clear min delay
    //set alarm/clock hours
            if (set_hour)        // set  hour
                 begin
                     if ((hour_del == 0) || (hour_del >= 15 )) // first toggle on key press or 1.5 sec delay
                           begin
                              if (set_alarm && mode == 1)  // Set alarm and 24 hour ?
                                  if(tmp_ahour >= 23)      // 24 hour mode?
                                      tmp_ahour = 0;       // Yes - Zero ahour
                                  else
                                      tmp_ahour = tmp_ahour + 1; // No - bump ahour
                              else if (set_alarm && mode == 0)   // Set alarm and 12 hour ?
                                  if(tmp_ahour >= 12)      // 12 hour mode?
                                  else
                              else if (!set_alarm && mode == 1)  // Set clock and 24 hour ?
                                  if(tmp_chour >= 23)      // 24 hour mode?
                                      tmp_chour = 0;       // Yes - Zero clock hour
                                  else
                                      tmp_chour = tmp_chour + 1; // No - bump clock hour
                              else if (!set_alarm && mode == 0)  // Set clock and 12 hour ?
                                  if(tmp_chour >= 12)      // 12 hour mode?
                                  else
                              if (hour_del <= 14)          // Fast delay up?
                              hour_del <= hour_del +1;     // No - Bump fast delay
                           end
                     else if (hour_del <= 14)              // 1.5 sec delay for fast speed
                              hour_del <= hour_del +1;     // Bump delay tenths of a sec
                  end
             else
                  hour_del = 0; // Clear hour delay
    //Normal clock operation
    // This code is entered once every tenth second
    // Turn decimal point and LED #1 on for approx .5 sec
            if (tenth_counter >= 5)
                 begin
                     dp_tmp <= 1;    // Turn decimal point off
                     LED16 <= 0;     // Turn LED off
                 end
             else
                 begin
                     dp_tmp <= 0;    // Turn decimal point on
                     LED16 <= 1;     // Turn LED on
                 end
    // Advance count on ninth of ten "tenth counts"
    // tmp_csec, cmin, chour > clock second, minuter, hours
             if (tenth_counter >= 9)                  //advance time if tenth count is 9
                   begin
                     tenth_counter <= 0;              // Reset tenth counter
                     if(tmp_csec >= 59)               // second > 59 then minute increases
                         begin
                             tmp_csec <= 0;            // clear second count
                             tmp_cmin <= tmp_cmin + 1; // bump the minute count
                         end
                     else
                         begin
                             tmp_csec <= tmp_csec + 1; //bump the second count
                         end
                     if(tmp_cmin >= 59)                // minute > 59 then hour increases
                         begin
                             tmp_cmin <= 0;            // clear the minute count
                             tmp_chour <= tmp_chour + 1;// bump the hour count
                         end
                      else
                         begin
                         end
                     if(mode == 1 && tmp_chour >= 24)   // 24 hour mode = 1 12 hour = 0
                             tmp_chour <= 0;            // 24 hours 0-23
                     else  if (mode == 0 && tmp_chour >= 13)
                             tmp_chour <= 1;            // 12 hour mode 1-12
                   end
              else
                   tenth_counter <= tenth_counter + 1;  // Bump tenth counter
      end
    Points: 81,996, Level: 69
    Apr 2014
    16,642
    81,996
    69
    Re: Verilog alarm clock time advancing not working correctly ..
    I expect:
    At the same time when
    * tenth_counter is reset to zero
    * you also need to increment the seconds counter.
    Allways.
    But in your code both lines are far apart and one is behind an additional "IF".
    Could you show us your flow chart? If you didn't draw already, then do it now.
    Did you run a simulation of your code? Or at least take a piece of paper and a pencil to do the same by hand.
    Points: 32,398, Level: 43
    ads-ee's Avatar
    Sep 2013
    USA
    7,489
    32,398
    43
    Don't mix blocking and non-blocking assignments in a edge triggered always block. Only use non-blocking assignments in clocked logic and blocking in combonational always blocks.
    Using blocking assignments with code like this:
                                  else
    causes synthesis to generate a FF -> add_1 -> compare code increasing the combinational logic path between flip-flops. Occasionally you might want to take advantage of this, but with a Verilog newbie you want to avoid anything like this.
    The structure of this code seems somewhat convoluted for the task.
    Seems to me you aren't generating a 10th sec counter enable to run the sec/min/hr counters. Try looking up pipelined counters and structure the code like those types of counters, the only difference between a clock counter and a binary pipelined counter is the rollover conditions of each stage.
    Typical pipelined counter (for a clock) with enable would be:
    1. 1/10 sec counter, rolls over every 1 sec.
    2. enable code to generate a pulse every 1 sec (can use the 1/10 sec counter rollover condition)
    3. sec counter, counts on every 1 sec enable, rolls over on a count of 59
    4. min counter, counts on the sec counter equal to 59 on a 1 sec enable
    5. hr counter, counts on the min counter equal to 59 on a 1 sec enable
    Mar 2020
    Orlando, Fla
    33
    Thank you for the reply! I just noticed that I got a Synthesis warning message ..
    "[Synth 8-6014] Unused sequential element tmp_csec_reg was removed. ["C:/Verilog/AlarmClock/AlarmClock.srcs/sources_1/imports/Alarm Clock/AlarmClockMod.v":98]"
    This refers to the line marked with <<< below. Maybe this has something to do with my problem? This is how the reg is identified.
    code snip...
     reg [24:0] first_counter;          // .1 sec counter for rapid time set
     reg [3:0] tenth_counter;           // 1 sec counter
     reg [5:0] tmp_chour, tmp_cmin, tmp_csec;                 <<<<<<<<<<<<<<<<
     reg [5:0] tmp_ahour, tmp_amin, tmp_asec;
    begin
           if (reset)
                     tmp_chour <= 4'b0000;
                     tmp_cmin  <= 4'b0000;
                     tmp_csec  <= 4'b0000;                 <<<<<<<<< line 98
                   end
                 begin
    Thanks. Jim
    Mar 2020
    Orlando, Fla
    33
    ads-ee Thank you! I have changed all the code to non_blocking. The tenth counter is a 4 bit counter initialized to 0.
    All this code is executes every .1 sec.
        first_counter = 0;
        tenth_counter = 0;
        first_toggle = 0;
    .....and is tested for a "nine" count before the time code and incremented after the time code.
             if (tenth_counter >= 9)                  //advance time if tenth count is 9  <<<<<<<<<
                   begin
                     tenth_counter <= 0;              // Reset tenth counter                           <<<<<<<<<<
                         begin
                         end
                     else
                         begin
                         end
                         begin
                         end
                      else
                         begin
                         end
                   end
              else
                   tenth_counter <= tenth_counter + 1;  // Bump tenth counter          <<<<<<<<<<<<
    Thanks. Jim
    Well, I seem to have found the problem.
                   begin
                         begin
                             tmp_cmin <= tmp_cmin + 1; // bump the minute count    <<<<<<<<<<<<<<<<<<<
                         end
                     else
                         begin
                         end
                         begin
                         end
                      else
                         begin
                         end
    The Synthesis was not happy with two "tmp_cmin <= tmp_cmin + 1" statements ... which also caused the min to advance incorrectly. Why it caused the "[Synth 8-6014] Unused sequential element tmp_csec_reg was removed. ["C:/Verilog/AlarmClock/AlarmClock.srcs/sources_1/imports/Alarm Clock/AlarmClockMod.v":98]" error of the prior post, I don't know.
    Anyway, I have revised this part of the code to fix a glitch .. "min unit digit reseting to zero before the tens digit" .. to this...
             if (tenth_counter >= 9)                         // advance time if tenth count is 9
                   begin
                         begin
                            if(tmp_cmin >= 59)
                                begin                        // minute > 59 then hour increases
                                   if(mode == 1 && tmp_chour >= 23)   // 24 hour mode = 1 hours 0-23
                                       tmp_chour <= 0;       // set the hour count to 0
                                   else
                                       tmp_chour <= tmp_chour +1;// bump the hour count
                                   if (mode == 0 && tmp_chour >= 12) // 12 hour mode = 0 hours 1-12
                                       tmp_chour <= 1;       // set the hour count to 1
                                   else
                                end
                            else
                         end
                      else
                            tmp_csec <= tmp_csec + 1;     // bump the second count
                 end
              else
      end
    ....and now all works correctly.
    Thanks guys for your time!
    Jim
    ads-ee's Avatar
    Sep 2013
    USA
    7,489
    32,398
    43
    Your code is difficult to read with all the extra indents and there are too many nested if's. IMO coding in HDLs you should limit both the nesting and the indenting along with not combining a bunch of different signals into a single always block. e.g.
    Code Verilog - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    66
    67
    68
    69
    70
    71
    72
    73
    74
    75
    76
    77
    78
    79
    80
    81
    82
    83
    84
    85
    86
    87
    88
    89
    90
    `timescale 1ns/1ps
    module pipe_cntr (
      input clk,
      input rst,
      output [8:0] cntr
      reg  [2:0]  cnt_hi;
      reg  [2:0]  cnt_mi;
      reg  [2:0]  cnt_lo;
      wire        tc_lo;
      wire        tc_mi;
      assign cntr = {cnt_hi, cnt_mi, cnt_lo};
      // terminal count of the lower two stages
      assign tc_lo = cnt_lo == 3'h 7;
      assign tc_mi = cnt_mi == 3'h 7;
      // lower counter, increments continuously
      always @(posedge clk, posedge rst) begin
        if (rst) begin
          cnt_lo <= 0;
        end else if (cnt_lo < 3'h 7) begin
          cnt_lo <= cnt_lo + 1;
        end else begin
          cnt_lo <= 0;
        end
      end
      // middle counter only counts if we are at the terminal count of the
      // lower counter
        if (rst) begin
          cnt_mi <= 0;
        end else if (tc_lo) begin
          if (cnt_mi < 3'h 7) begin
            cnt_mi <= cnt_mi + 1;
          end else begin
            cnt_mi <= 0;
          end
        end
      end
      // high counter only counts if we are at the terminal count of both
      // the lower and middle counter
        if (rst) begin
          cnt_hi <= 0;
        end else if (tc_lo && tc_mi) begin
          if (cnt_hi < 3'h 7) begin
            cnt_hi <= cnt_hi + 1;
          end else begin
            cnt_hi <= 0;
          end
        end
      end
    endmodule
    module tb;
      reg clk, rst;
      wire [8:0] cntr;
      initial clk = 0;
      always #10 clk = ~clk;
      pipe_cntr  uut (
        .clk    (clk),
        .rst    (rst),
        .cntr   (cntr)
      initial begin
        rst = 1;
        #100;
        rst = 0;
        #10000;
        $stop;
      end
    endmodule
    Is an example of how I would write a pipelined counter with different counters for each stage (3 stages), being broken up into each stage makes it easy to see how the counters interact.
    You can run the simulation and see how the counters work with the terminal counts letting the next stage know when to count.
  7. #7
    Mar 2020
    Orlando, Fla
    33
    ads-ee. Thank you much! I will check out the pipelined counter technique. Phew..a lot to learn!
    Jim
