Results 1 to 5 of 5
    Member level 3
    Points: 589, Level: 5
    Feb 2019
    64
    589
    Problem creating coregen in ISE 14.5
    Greetings ... a couple of days ago I am trying to take a project that was done in Vivado 2017.3 to ISE 14.5 since it is required to implement it on a Virtex-5 device. This project includes some IPs that are not supported in ISE 14.5. So I decided to replace them with compatible IPs, but I am having trouble creating a new coregen from a new IP source (CORE Generator & Architecture Wizard) since I have the following message.
    -The IP Catalog has been reloaded
    To this problem I was suggested the following solution.
    https://www.xilinx.com/support/answers/53695.html
    Unfortunately, I still have the same message, and I still can't generate the coregen.
    Someone who can help me with this problem please, thank you in advance.
    Points: 32,521, Level: 44
    ads-ee's Avatar
    Sep 2013
    USA
    7,527
    32,521
    44
    Re: Problema para crear coregen en ISE 14.5
    Are you using the webpack version of ISE? ISE webpack doesn't support any Virtex parts. I also don't think ISE uses the Vivado licensing (in case you only have Vivado licenses, I can't verify as the license server has both old licenses and the newer Vivado ones).
    Member level 3
    Feb 2019
    64
    589
    I am using the Systema Edition but as you say the license I use for Vivado may not work with ISE. What can I do in this case?
    ads-ee's Avatar
    Sep 2013
    USA
    7,527
    32,521
    44
    I also recalled that ISE doesn't necessarily install everything for all families unless explicitly selected in the installation dialogs. As I haven't used ISE in years, I don't remember how to check which families are installed.
    You do know that ISE 14.7 is out for installation on Win10 as a VM (or Linux)? If you've installed it on a Linux or a Win7 machine you are probably okay, but Win10 wouldn't be supported for ISE 14.4 to 14.7, which is why Xilinx has a linux VM to run under Win10.
    This VM version might let you use a recent license or it might get around running on an unsupported OS.
    Member level 3
    Feb 2019
    64
    589
    thanks for all the help adds-ee, I commented that I solved my problem ... the version I had downloaded from ISE consisted of a compressed file with the complete installer, but there is also an installer consisting of 4 compressed files. Install this version but then I had problems with the compatibility of ISE 14.5 with Windows 10, but I solved it with the following link.
    https://www.eevblog.com/forum/fpga/g...dows-8-64-bit/
