Results 1 to 20 of 20
    Advanced Member level 3
    Points: 4,171, Level: 15
    Feb 2016
    820
    4,171
    15
    LDO transient performance enhancement circuit understanding
    For the following LDO circuit, how does the transient performance enhancement circuit sub-block in green color works ?
    Feb 2016
    820
    4,171
    15
    Re: LDO transient performance enhancement circuit understanding
    I tried to replicate the above LDO circuit in LTSpice, but it does not work yet ....
    Points: 31,659, Level: 43
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,650
    31,659
    43
    Where is your transient source so you expect a transient response ??
    You have to change VDD by transient STEP PULSE source to achieve a transient response..Otherwise everything is in steady state response so DC ..
    Feb 2016
    820
    4,171
    15
    For this LDO circuit , I have pretty good transient output voltage V(vout) for a 100k sine input on Vin.
    But it goes very bad when I use 1MEG sine input on Vin.
    Any advice ?
    LDO.asc
    Version 4
    SHEET 1 3764 1620
    WIRE -416 80 -512 80
    WIRE -272 80 -416 80
    WIRE -208 80 -272 80
    WIRE 96 80 -208 80
    WIRE 144 80 96 80
    WIRE 1216 80 144 80
    WIRE 2064 80 1216 80
    WIRE 2320 80 2064 80
    WIRE 2384 80 2320 80
    WIRE 2784 80 2384 80
    WIRE 2848 80 2784 80
    WIRE 3152 80 2848 80
    WIRE 3216 80 3152 80
    WIRE 3472 80 3216 80
    WIRE 3536 80 3472 80
    WIRE -208 128 -208 80
    WIRE 96 128 96 80
    WIRE 2384 128 2384 80
    WIRE 2784 128 2784 80
    WIRE 3152 128 3152 80
    WIRE 3472 128 3472 80
    WIRE 2064 144 2064 80
    WIRE 2064 144 2016 144
    WIRE 2016 160 2016 144
    WIRE -272 176 -272 80
    WIRE -208 176 -272 176
    WIRE 144 176 144 80
    WIRE 144 176 96 176
    WIRE 2320 176 2320 80
    WIRE 2384 176 2320 176
    WIRE 2848 176 2848 80
    WIRE 2848 176 2784 176
    WIRE 3216 176 3216 80
    WIRE 3216 176 3152 176
    WIRE 3536 176 3536 80
    WIRE 3536 176 3472 176
    WIRE -80 208 -160 208
    WIRE -16 208 -80 208
    WIRE 48 208 -16 208
    WIRE 2064 208 2064 144
    WIRE 2064 208 2016 208
    WIRE 2640 208 2432 208
    WIRE 2736 208 2640 208
    WIRE 3104 208 3056 208
    WIRE 3424 208 3392 208
    WIRE -16 240 -16 208
    WIRE 1968 240 -16 240
    WIRE -512 272 -512 80
    WIRE 2640 304 2640 208
    WIRE 2784 304 2784 224
    WIRE 2784 304 2640 304
    WIRE 2016 320 2016 256
    WIRE 2384 320 2384 224
    WIRE 2384 320 2016 320
    WIRE 3056 320 3056 208
    WIRE 3056 320 2384 320
    WIRE 3392 320 3392 208
    WIRE 3392 320 3056 320
    WIRE -208 336 -208 224
    WIRE -80 336 -80 208
    WIRE -80 336 -208 336
    WIRE 496 368 448 368
    WIRE 1040 368 496 368
    WIRE 1216 368 1216 80
    WIRE 1216 368 1040 368
    WIRE 1536 368 1216 368
    WIRE 1584 368 1536 368
    WIRE 496 384 496 368
    WIRE 1536 384 1536 368
    WIRE -512 432 -512 352
    WIRE 448 432 448 368
    WIRE 496 432 448 432
    WIRE 1584 432 1584 368
    WIRE 1584 432 1536 432
    WIRE 640 464 544 464
    WIRE 1488 464 640 464
    WIRE 2432 560 2368 560
    WIRE 496 592 496 480
    WIRE 640 592 640 464
    WIRE 640 592 496 592
    WIRE 2320 608 1840 608
    WIRE 2368 608 2368 560
    WIRE 2432 608 2432 560
    WIRE 2432 608 2416 608
    WIRE 2672 608 2432 608
    WIRE 3392 608 3392 320
    WIRE 3392 608 2672 608
    WIRE 1040 624 1040 368
    WIRE 1040 624 992 624
    WIRE 992 640 992 624
    WIRE 1840 640 1840 608
    WIRE 2016 672 2016 320
    WIRE 2064 672 2016 672
    WIRE 1040 688 1040 624
    WIRE 1040 688 992 688
    WIRE 2016 688 2016 672
    WIRE 2560 704 2512 704
    WIRE 2672 704 2672 608
    WIRE 2672 704 2560 704
    WIRE 3472 704 3472 224
    WIRE 3536 704 3472 704
    WIRE -208 720 -208 336
    WIRE 944 720 -208 720
    WIRE 2512 720 2512 704
    WIRE 2064 736 2064 672
    WIRE 2064 736 2016 736
    WIRE 1536 768 1536 480
    WIRE 1840 768 1840 704
    WIRE 1840 768 1536 768
    WIRE 1968 768 1840 768
    WIRE 2560 768 2560 704
    WIRE 2560 768 2512 768
    WIRE 2336 800 2336 656
    WIRE 2464 800 2336 800
    WIRE 96 832 96 224
    WIRE 96 832 -64 832
    WIRE 848 880 800 880
    WIRE 992 880 992 736
    WIRE 992 880 848 880
    WIRE 1184 880 992 880
    WIRE 1232 880 1184 880
    WIRE 2336 880 2336 800
    WIRE 2512 880 2512 816
    WIRE 2512 880 2336 880
    WIRE -208 896 -208 720
    WIRE 96 896 96 832
    WIRE 800 896 800 880
    WIRE 1232 896 1232 880
    WIRE 1872 928 1760 928
    WIRE 3392 928 3392 608
    WIRE 3392 928 1936 928
    WIRE -208 944 -272 944
    WIRE 160 944 96 944
    WIRE 848 944 848 880
    WIRE 848 944 800 944
    WIRE 1184 944 1184 880
    WIRE 1184 944 848 944
    WIRE 1232 944 1184 944
    WIRE -64 976 -64 832
    WIRE -64 976 -160 976
    WIRE 48 976 -64 976
    WIRE 704 976 688 976
    WIRE 752 976 704 976
    WIRE 1664 976 1280 976
    WIRE 2992 976 2640 976
    WIRE 3152 976 3152 224
    WIRE 3152 976 2992 976
    WIRE 688 1008 688 976
    WIRE 3472 1008 3472 704
    WIRE 2512 1040 2512 880
    WIRE 2784 1040 2784 304
    WIRE 3152 1040 3152 976
    WIRE 2512 1088 2448 1088
    WIRE 2784 1088 2720 1088
    WIRE 3216 1088 3152 1088
    WIRE 2640 1120 2640 976
    WIRE 2640 1120 2560 1120
    WIRE 2992 1120 2992 976
    WIRE 2992 1120 2832 1120
    WIRE 3104 1120 2992 1120
    WIRE 96 1136 96 992
    WIRE 96 1136 -64 1136
    WIRE 688 1136 688 1088
    WIRE 800 1168 800 992
    WIRE 800 1168 640 1168
    WIRE 1232 1168 1232 992
    WIRE 1376 1168 1232 1168
    WIRE -208 1200 -208 992
    WIRE 96 1200 96 1136
    WIRE 496 1232 496 592
    WIRE 800 1232 800 1168
    WIRE 1232 1232 1232 1168
    WIRE 1536 1232 1536 768
    WIRE -208 1248 -272 1248
    WIRE 160 1248 96 1248
    WIRE 1664 1264 1664 976
    WIRE 3360 1264 1664 1264
    WIRE 3472 1264 3472 1088
    WIRE 3472 1264 3360 1264
    WIRE -64 1280 -64 1136
    WIRE -64 1280 -160 1280
    WIRE 48 1280 -64 1280
    WIRE 496 1280 432 1280
    WIRE 864 1280 800 1280
    WIRE 1232 1280 1168 1280
    WIRE 1600 1280 1536 1280
    WIRE 640 1312 640 1168
    WIRE 640 1312 544 1312
    WIRE 672 1312 640 1312
    WIRE 752 1312 672 1312
    WIRE 1376 1312 1376 1168
    WIRE 1376 1312 1280 1312
    WIRE 1488 1312 1376 1312
    WIRE -208 1376 -208 1296
    WIRE 3472 1392 3472 1264
    WIRE 496 1424 496 1328
    WIRE 800 1424 800 1328
    WIRE 800 1424 496 1424
    WIRE 1008 1424 800 1424
    WIRE 1232 1424 1232 1328
    WIRE 1232 1424 1008 1424
    WIRE 1536 1424 1536 1328
    WIRE 1536 1424 1232 1424
    WIRE 1008 1472 1008 1424
    WIRE -208 1520 -208 1456
    WIRE -64 1520 -208 1520
    WIRE 96 1520 96 1296
    WIRE 96 1520 -64 1520
    WIRE 672 1536 672 1312
    WIRE 1760 1536 1760 928
    WIRE 1760 1536 672 1536
    WIRE 2016 1536 2016 784
    WIRE 2512 1536 2512 1136
    WIRE 2512 1536 2016 1536
    WIRE 2784 1536 2784 1136
    WIRE 2784 1536 2512 1536
    WIRE 3152 1536 3152 1136
    WIRE 3152 1536 2784 1536
    WIRE 3472 1536 3472 1472
    WIRE 3472 1536 3152 1536
    WIRE -64 1568 -64 1520
    WIRE 3472 1568 3472 1536
    FLAG 432 1280 0
    FLAG 864 1280 0
    FLAG 1168 1280 0
    FLAG 1600 1280 0
    FLAG 1008 1472 0
    FLAG -512 432 0
    FLAG 3472 1568 0
    FLAG 3216 1088 0
    FLAG 2720 1088 0
    FLAG 2448 1088 0
    FLAG 3536 704 Vout
    IOPIN 3536 704 Out
    FLAG 688 1136 0
    FLAG 704 976 Vref
    FLAG -416 80 Vin
    FLAG 3360 1264 Vfb
    FLAG -272 1248 0
    FLAG 160 1248 0
    FLAG -64 1568 0
    FLAG -272 944 0
    FLAG 160 944 0
    SYMBOL pmos4 48 128 R0
    WINDOW 123 62 94 Left 2
    SYMATTR Value2 L=0.18u W=6u m=2
    SYMATTR InstName M2
    SYMATTR Value PM
    SYMBOL pmos4 1488 384 R0
    WINDOW 123 56 100 Left 2
    SYMATTR Value2 L=0.18u W=6u m=4
    SYMATTR InstName M7
    SYMATTR Value PM
    SYMBOL pmos4 544 384 M0
    WINDOW 123 -11 101 Left 2
    SYMATTR InstName M8
    SYMATTR Value PM
    SYMBOL pmos4 1968 160 R0
    SYMATTR InstName M9
    SYMATTR Value PM
    SYMBOL pmos4 944 640 R0
    SYMATTR InstName M10
    SYMATTR Value PM
    SYMBOL nmos4 544 1232 M0
    SYMATTR Value2 L=0.18u W=6u m=8
    SYMATTR InstName M11
    SYMATTR Value NM
    SYMBOL nmos4 752 1232 R0
    WINDOW 123 -43 119 Left 2
    SYMATTR InstName M12
    SYMATTR Value NM
    SYMBOL pmos4 1280 896 M0
    WINDOW 0 43 30 Left 2
    SYMATTR InstName M13
    SYMATTR Value PM
    SYMBOL pmos4 752 896 R0
    SYMATTR InstName M15
    SYMATTR Value PM
    SYMBOL nmos4 1280 1232 M0
    SYMATTR InstName M16
    SYMATTR Value NM
    SYMBOL nmos4 1488 1232 R0
    WINDOW 123 -39 112 Left 2
    SYMATTR InstName M17
    SYMATTR Value NM
    SYMBOL voltage -512 256 R0
    WINDOW 123 24 124 Left 2
    WINDOW 39 0 0 Left 0
    SYMATTR Value2 AC 1
    SYMATTR InstName Vin
    SYMATTR Value SINE(3.3 1 1MEG)
    SYMBOL cap 1936 912 R90
    WINDOW 0 0 32 VBottom 2
    WINDOW 3 32 32 VTop 2
    SYMATTR InstName C1
    SYMATTR Value 1p
    SYMBOL res 3456 992 R0
    SYMATTR InstName R1
    SYMATTR Value 10k
    SYMBOL res 3456 1376 R0
    SYMATTR InstName R2
    SYMATTR Value 10k
    SYMBOL pmos4 1968 688 R0
    SYMATTR InstName M18
    SYMATTR Value PM
    SYMBOL cap 1824 640 R0
    SYMATTR InstName C2
    SYMATTR Value 1p
    SYMBOL pmos4 2432 128 M0
    WINDOW 123 -77 116 Left 2
    SYMATTR InstName M19
    SYMATTR Value PM
    SYMBOL pmos4 3424 128 R0
    SYMATTR Value2 L=0.18u W=6u m=2000
    SYMATTR InstName M20
    SYMATTR Value PM
    SYMBOL pmos4 2416 656 M270
    SYMATTR Value2 L=0.18u W=6u m=1
    SYMATTR InstName M22
    SYMATTR Value PM
    SYMBOL pmos4 2464 720 R0
    SYMATTR InstName M21
    SYMATTR Value PM
    SYMBOL pmos4 3104 128 R0
    SYMATTR InstName M23
    SYMATTR Value PM
    SYMBOL nmos4 3104 1040 R0
    SYMATTR InstName M24
    SYMATTR Value NM
    SYMBOL nmos4 2832 1040 M0
    WINDOW 123 -77 114 Left 2
    SYMATTR InstName M25
    SYMATTR Value NM
    SYMBOL nmos4 2560 1040 M0
    SYMATTR InstName M26
    SYMATTR Value NM
    SYMBOL pmos4 2736 128 R0
    SYMATTR InstName M27
    SYMATTR Value PM
    SYMBOL voltage 688 992 M0
    SYMATTR InstName Vref
    SYMATTR Value DC 1.1V
    SYMBOL nmos4 -160 1200 M0
    SYMATTR InstName M1
    SYMATTR Value NM
    SYMBOL nmos4 48 1200 R0
    SYMATTR InstName M3
    SYMATTR Value NM
    SYMBOL nmos4 -160 896 M0
    SYMATTR InstName M4
    SYMATTR Value NM
    SYMBOL nmos4 48 896 R0
    SYMATTR InstName M5
    SYMATTR Value NM
    SYMBOL pmos4 -160 128 M0
    SYMATTR InstName M6
    SYMATTR Value PM
    SYMBOL res -192 1360 M0
    SYMATTR InstName R3
    SYMATTR Value 22k
    TEXT 64 32 Left 2 !.lib mosfet_018.lib
    TEXT 344 32 Left 2 !.tran 100u
    TEXT 520 32 Left 2 !;.ac dec 100 1 1g
    Points: 5,280, Level: 17
    Nov 2013
    772
    5,280
    17
    Why don't you filter the constant-Gm bias circuit? And you have uA consumption, PSRR is strongly frequency dependent, these 2 things together result above. No surprises.
    "Try SCE to AUX." /John Aaron/
    Feb 2016
    820
    4,171
    15
    it is consuming less than 300uA , and as I have tried, increasing current limiting resistor R3 value does not really help in improving PSRR.
    Do you have a decent CMOS circuit for filtering the constant-Gm bias circuit ?
  7. #7
    Nov 2013
    772
    5,280
    17
    I don't have, I only suggest to add capacitors in paralel with the gate-source of M2 and M10. Or add series resistor with the gates, maybe the combination of them. And don't use minimal length for transistors where it is not necessary, that improves PSRR.
  8. #8
    Feb 2016
    820
    4,171
    15
    How is minimal length related to PSRR ?
  9. #9
    Feb 2016
    820
    4,171
    15
    What do you think about the following gain margin and phase margin plot ?
    How to move the zero at the high frequency zone to lower frequency range ?
    LDO_gain_phase_margin.asc
    Version 4
    SHEET 1 3764 1620
    WIRE 96 80 -208 80
    WIRE 144 80 96 80
    WIRE 1216 80 144 80
    WIRE 96 128 96 80
    WIRE 144 176 144 80
    WIRE 144 176 96 176
    WIRE 48 208 -16 208
    WIRE 3472 608 3472 224
    WIRE 3472 608 3392 608
    WIRE 3472 704 3472 608
    WIRE 96 832 96 224
    WIRE 96 832 -64 832
    WIRE 96 896 96 832
    WIRE 160 944 96 944
    WIRE 48 976 -64 976
    WIRE 96 1136 96 992
    WIRE 2112 1264 1664 1264
    WIRE 2192 1264 2112 1264
    WIRE 3472 1264 2272 1264
    FLAG 432 1280 0
    FLAG 864 1280 0
    FLAG 1168 1280 0
    FLAG 1600 1280 0
    FLAG 1008 1472 0
    FLAG -512 432 0
    FLAG 3472 1568 0
    FLAG 3216 1088 0
    FLAG 2720 1088 0
    FLAG 2448 1088 0
    FLAG 3536 704 Vout
    IOPIN 3536 704 Out
    FLAG 688 1136 0
    FLAG 704 976 Vref
    FLAG -416 80 Vin
    FLAG 2112 1264 Vfb
    FLAG -272 1248 0
    FLAG 160 1248 0
    FLAG -64 1568 0
    FLAG -272 944 0
    FLAG 160 944 0
    SYMATTR InstName M2
    SYMATTR Value PM
    SYMATTR InstName M7
    SYMATTR Value PM
    SYMATTR InstName M8
    SYMATTR Value PM
    SYMATTR InstName M9
    SYMATTR Value PM
    SYMATTR Value PM
    SYMATTR Value NM
    SYMATTR Value NM
    SYMATTR Value PM
    SYMATTR Value PM
    SYMATTR Value NM
    SYMATTR Value NM
    SYMATTR Value2 AC 1
    SYMATTR InstName C1
    SYMATTR Value 1p
    SYMATTR InstName R1
    SYMATTR Value 10k
    SYMATTR InstName R2
    SYMATTR Value 10k
    SYMATTR Value PM
    SYMATTR InstName C2
    SYMATTR Value 1p
    SYMATTR Value PM
    SYMATTR Value PM
    SYMATTR Value PM
    SYMATTR Value PM
    SYMATTR Value PM
    SYMATTR Value NM
    SYMATTR Value NM
    SYMATTR Value NM
    SYMATTR Value PM
    SYMATTR InstName M1
    SYMATTR Value NM
    SYMATTR InstName M3
    SYMATTR Value NM
    SYMATTR InstName M4
    SYMATTR Value NM
    SYMATTR InstName M5
    SYMATTR Value NM
    SYMATTR InstName M6
    SYMATTR Value PM
    SYMATTR InstName R3
    SYMATTR Value 22k
    SYMBOL voltage 2288 1264 R90
    WINDOW 0 -32 56 VBottom 2
    WINDOW 3 32 56 VTop 2
    WINDOW 123 60 56 VTop 2
    SYMATTR InstName V1
    SYMATTR Value 0
    SYMATTR Value2 AC 1
    TEXT 344 32 Left 2 !;.tran 100u
    TEXT 520 32 Left 2 !.ac dec 100 1 1g
  10. #10
    Feb 2016
    820
    4,171
    15
    Why does the transient simulation around 10us have a lot of noise ?
    Where is the actual root cause for such deterministic noise at 10us after simulation starts ? And any idea how to eliminate it entirely from the noise source ?
  11. #11
    Nov 2013
    772
    5,280
    17
    At every low supply voltage moment there is some "noise" on the output. I think it tells that your circuit is unstable at lower supply voltages. Simulate stability with different supply voltage values, check gain and phase margin.
    I guess your transistors are not good for your application. What kind of model are you using?
  12. #12
    Feb 2016
    820
    4,171
    15
    At lower supply voltage such as 2.5V , LDO does not work anymore.
    I am using this mosfet model
    What do you suggest ?
    I am not sure if FreePDK15 model could actually be used with LTSpice
    In this case, I think I need some other mosfet models.
  13. #13
    Nov 2013
    772
    5,280
    17
    how much is the minimum and maximum supply voltage do you want? choose transistors which are fit for both. or choose a simplier LDO. or if it is for learning purpose simply don't use low supply.
  14. #14
    Feb 2016
    820
    4,171
    15
    maximum = 5V , minimum = 2.5V
    https://user.eng.umd.edu/~newcomb/co...c180nmcmos.lib also resulted in similar noise issue.
  15. #15
    Nov 2013
    772
    5,280
    17
    Could you show an open-loop gain plot? It is stability issue, you have to improve stability. You have to find which transistor enters triode region when you apply low supply. And make surre these transistors can operate on 5V.
  16. #16
    Feb 2016
    820
    4,171
    15
    Note: output load capacitance, CL = 1uF
    and changing Vin parameters such as 3.3V to 2.5V , as well as lowering the Vin frequency from 1MHz to below 1kHz do not change the phase margin.
  17. #17
    Nov 2013
    772
    5,280
    17
    Are you sure above figure is simulated next to 2.5V DC supply? I think we should see some minor changes at least between 2.5V and 3.3V values. Try to plot both on the same figure. Or you could analyse what is the minimum supply which cause significant change in AC behaviour. BTW what do you mean by lowering frequency parameters do not change the phase margin, this is an AC plot?
  18. #18
    Feb 2016
    820
    4,171
    15
    Look at Vin SINE() parameters
  19. #19
    Feb 2016
    820
    4,171
    15
    I have uploaded the LDO circuit at https://github.com/promach/LDO
    I have few questions :
    1. Why in the second bode plot (which might be problematic PSRR), gain going up near unity-gain frequency is often a sign of instability ?
    2. Why is there some initial noise disturbance around 10us during start-up ?
    3. What is the purpose of M2 and M26 ?
    4. Could anyone explain the mechanism of transient performance enhancement circuit consisting of M19, M27, M23, M24 and M25 ?
    5. Any suggestion on suitable test circuit for load regulation metric check ?
  20. #20
    Feb 2016
    820
    4,171
    15
    The desired Vout is 2.2V
    See Vref, R1 and R2
    Iout = 0 , Vout = 3.2V .........
    Iout = 3A, Vout = 2V
    See LDO_max_Iout.zip
