Results 1 to 5 of 5
    Junior Member level 2
    Points: 271, Level: 3
    Apr 2019
    22
    271
    Calculating BLDC controller efficiency
    Hello guys,
    I am working on bldc motor controller project and now i have to calculate its efficiency.
    What is the equipment used to calculate BLDC controller efficiency in industry level?
    thanks in advance.
    Points: 82,022, Level: 69
    Apr 2014
    16,646
    82,022
    69
    Re: Calculating BLDC controller efficiency
    What efficiency?
    Motor_mechanical_power_out / electrical_DC_power_in ?
    Apr 2019
    22
    271
    What efficiency?
    yeah that's the formula used.
    But I want to know what are the equipments used to test the bldc motor controller.
    To find,
    efficiency
    torque and etc.
    Apr 2014
    16,646
    82,022
    69
    I just did an internet search for "motor test equippment" ... a lot of good looking results.
    Did't you try this in your own?
    And for DC.. maybe just voltage and current measurement is sufficient.
    Points: 54,156, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    13,200
    54,156
    56
    A paddle in liquid is a simple way to load a motor. You alter it with ease, by immersing less or more of the paddle. Or by using liquids with less or more viscosity.
    In engineering class we tested our homemade turbines, by clamping a slotted block of metal around the rotating shaft. We tightened the clamp until the block just started to bind. Then rpm was measured by stroboscope. This became the turbine's torque score.
    Usually a motor has a certain rpm which produces the most torque, or most work delivered to a load. In other words its most efficient operating rpm. A lot of things contribute, including your controller of course.
