Results 1 to 16 of 16
    Junior Member level 3
    Points: 2,241, Level: 10
    Sep 2008
    28
    2,241
    10
    Problem with using ic uA733
    Does anyone use uA733.The input signal is 30mv,17MHz.I expexted about 300mv.
    I sending schematic diagram.
    Bestregards.
    Points: 266,359, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,544
    266,359
    100
    Re: Problem with using ic uA733
    The input signal is 30mv,17MHz.I expected about 300mv.
    What is input signal in your circuit? How do you measure it? How should the problem be related to uA733?
    Sep 2008
    28
    2,241
    10
    Hello again.I measured it with osciloscope.How is sed in datasheed, conecting leads
    11,4/or 12,3-this can give as all aplification coeficients.Output signal is lower than
    input.I cannot apmplifie this signal.By the way,signal is 40MHz not 17MHz.I made a mistake.
    Is it conection is wrong ot this circuit,has difficulties with aplification.In the datasheet is sed
    that they are up to 200MHz,but honsetly i am reserved.How can i decide the problem?
    I do not whant to conect a lot of tons uA733.Although leades are not conected together
    i mean 11,4 the amplification is 10.That means about 200mv in the output.
    Bestregards:Barosov/Bulgaria
    LZ6LB/73
    Points: 85,239, Level: 71
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    14,024
    85,239
    71
    What puzzles me is the pins of TX1 suggest it is a metal can package with pins to fit a 14-pin DIL profile. That almost certainly means it produces TTL level outputs. If I'm right, TX1 pin 8 should connect directly to the 'D' input of the flip-flop and the LM733 isn't needed at all.
    Points: 8,805, Level: 22
    Nov 2009
    Italy
    1,194
    8,805
    22
    From your schematic LM733 is supplied between 12V ad GND. The datasheet doesn't seem to say it can be used in a single supply configuration
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,544
    266,359
    100
    Input is biased to mid supply, no problem.
  7. #7
    Sep 2008
    28
    2,241
    10
    Good morning.I have just returned from night shift.I have two resistor
    to provide midle power supply.The uA733 is conected according to data
    sheet.
    Bestregards:Barosov
  8. #8
    Points: 83,808, Level: 70
    Apr 2014
    17,040
    83,808
    70
    May I ask why you use a differential amlifier when you just use one output?
    To measure gain you need to involve both outputs: Vout = VOut+ - VOut-
    Just to talk about the same datasheet: which amplifier exactly arou you using: LM733 or uA733? Which package?
  9. #9
    Sep 2008
    28
    2,241
    10
    ;*********************************************8888
    I am using uA733.I know if we using only one otput the amplifaing
    is a half.But output amplitude is lower that input only 20mv.That is fun.
    I want to understand where is the problem.I know that we cannot
    get otput about 2 or 3 volt with input-20mv in 40MHz,just with one chip
    we need minimum 2 or 3 chips.I want to understand why this chip
    doesnot want to aplifie.
    Good day.
  10. #10
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,544
    266,359
    100
    Can we please clarify the post #4 question. What's the oscillator type and has it really low output voltage in the 100 mV range, or even less?
  11. #11
    Sep 2008
    28
    2,241
    10
    ;************************************************* ********88
    Yes we can clarify the post.This is the oscilator schematic.
  12. #12
    Points: 15,655, Level: 30
    schmitt trigger's Avatar
    Apr 2013
    2,603
    15,655
    30
    Back in the late 80s I successfully built several video distribution amplifiers using the NE592, which is a exact equivalent of the LM733. It was single ended mode also.
    I am including the datasheets.
    I am also enclosing a snippet of the overall diagram.
    The differences that I see from your and my diagram:
    -I used a bipolar +/-6 volt supply, although your biasing configuration should also work.
    -I actually used the gain setting pins, which you are not.
    I would suggest that you solder a trimpot between gain adjust terminals G1a and G1b, as I am showing in my schematic.
    [/ATTACH][ATTACH=CONFIG]157973
    lm733cn.pdfNE592-D.PDF
    My batteries are recharged by "Helpful Post" ratings.
  13. #13
    Sep 2008
    28
    2,241
    10
    Thank's a lot for your help.What was the amplitude of the input signal
    of your shematic,and the freqwency?And what was the amplitude of output signal?
    Bestregards:Barosov
    LZ6LB.
  14. #14
    Apr 2013
    2,603
    15,655
    30
    It was NTSC video, meaning 4 Mhz and 2Vpp (drops down to 1 Vpp with 75 ohm termination)
  15. #15
    Sep 2008
    28
    2,241
    10
    Hello Brian.
    TX1 is fabric oscillator with 4 pins.It gives about 200mv at 40MHz
    clear sinosuid.I made one amplifier with FET input and other four
    transistors.With other oscillator that give 30mv at 17MHz,it give me
    about 2 volts output signal.If you interested I can send you schematic
    diagram.I will experiment other schematic.I must do FLL system that
    lock the freqwency of the band generator for transiever.
    Barosov.
  16. #16
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    14,024
    85,239
    71
    I would suggest using a comparator instead of an amplifier. The signal you need is to clock the logic devices, using a comparator will ensure you get a clean logic level output. If you use an amplifier you can get the amplitude you need but the edges will not be sharp so it may not give a consistent result.
