Results 1 to 7 of 7
    Points: 307, Level: 3
    Oct 2019
    51
    307
    Can you please explain how this N-Channel JFET with Diodes work?
    Hi!
    I've run into this N-Channel JFET with Diodes - IFD89. Can somebody please explain how it works and used? I don't get it why there are 2 diodes in that configuration.
    Thank you.
    Advanced Member level 2
    Points: 3,150, Level: 13
    Jan 2019
    574
    3,150
    13
    Re: Can you please explain how this N-Channel JFET with Diodes work?
    a place to start: n channel j fet:
    http://www.learningaboutelectronics....N-channel-JFET
    the diodes are an opportunity to protect the gate
    for example, consider the SOT353 case:
    pin 2 is the gate.
    by connecting pin 1 to "something", the gate is "clamped" to no more than
    a diode drop from the "something"
    if you connect pin 1 to the source, pin 5, the gate cannot be more than 1 diode
    drop above or below the source voltage
    note that on page 2 of the spec sheet, the gate diode voltage is 0.4 to 0.8 V
    so if pin 1 is connected to "something" the gate will not go more that 0.4 to 0.8 V above "something"
    nor will it go more that 0.4 to 0.8 V below "something"
    i don't see any use for the diodes.
    perhaps someone wiser than i has a better answer
    i suggest you contact InterFET and ask
    Points: 15,458, Level: 30
    schmitt trigger's Avatar
    Apr 2013
    2,574
    15,458
    30
    My first thought would also be gate protection.
    The datasheet mentions that "....and is optimized for low power audio applications. The integrated back to back diodes offers clamping and additional gate leakage."
    Not sure why one would want leakage.
    My batteries are recharged by "Helpful Post" ratings.
    Points: 265,369, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,367
    265,369
    100
    The diodes may be also used as replacement for a high ohmic bias resistor, e.g. in an electret microphone or pyroelectric IR sensor amplifier.
    Oct 2019
    51
    307
    I actually got it from here https://youtu.be/niZizzHBanA?t=436 about 2 months ago. And I didn't understand anything what was said in that video. So I came back to it to see if now I understand it better... Unfortunately, no. I guess I need more time to learn things.
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,367
    265,369
    100
    To understand the basic amplifier operation, you can place a high ohmic resistor instead of the diodes.
  7. #7
    Apr 2013
    2,574
    15,458
    30
    Makes sense....just a minuscule amount of bias!
