Results 1 to 12 of 12
    Points: 636, Level: 5
    Feb 2018
    53
    636
    setting bits in byte
    given page https://www.geeksforgeeks.org/set-cl...a-number-in-c/
    N = N | 1 << K
    where K is the bit that is to be set
    N = 1011 0101
    set the 6th bit of N
    N = 1011 0101 | 1 << 6
    What happens first OR th operation will perform or Bit will shift first
    Full Member level 3
    Points: 1,955, Level: 10
    Jul 2014
    West Coast
    180
    1,955
    10
    Re: setting bits in byte
    The compiler may just look at the expression and then use a machine code "set bit" instruction, so, no shift will actually take place. Look at the assembly language listing the compiler creates to confirm how it is actually executing the expression. This may vary from compiler to compiler, and of course depend on the assembly language instruction set of the CPU.
    Points: 30,356, Level: 42
    andre_teprom's Avatar
    Nov 2006
    Brazil
    9,105
    30,356
    42
    Blog Entries
    9
    Quote Originally Posted by ansh11 View Post
    Review C language fundamentals and search for "operator precedence chart" and you will realize that shift operations have precedence over logical operations; to avoid misinterpretation, whenever possible enclose with "(...)" expressions that need to be evaluated first.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    Points: 266,384, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,549
    266,384
    100
    There are a few points that are marked as implementation dependent in C language reference, but not this basic operator precedence thing. If the compiler does not follow the mandatory behavior, you should return it and call in your money.
    Nov 2006
    Brazil
    9,105
    30,356
    42
    Blog Entries
    9
    N = N | 1 << K
    Worthy to mention that you did not copied correctly the expression from the link:
    return (n | (1 << (k - 1)))
    In your above case, the result would not be the SET BIT opperation as expected.
    Feb 2018
    53
    636
    Quote Originally Posted by andre_teprom View Post
    Two operators are required to set a bet. logical OR, left shift operator
    Bitwise OR 1100 0010 | 0111 1100 = 1111 1110
    Bitwise left shift 1100 0010 << 1 = 100 00100
    I have to use both operators together now. How to set a bit?
  7. #7
    Nov 2006
    Brazil
    9,105
    30,356
    42
    Blog Entries
    9
    Confusing question, review post #5 anyway, there you can find both opperators together (in a single expression, if you meant that); anyway here it is as perhaps you want in C-format :
    n = (n | (1 << (k - 1)))
  8. #8
    Feb 2018
    53
    636
    I understand that if I have to set a bit in the byte, then what would the result?
    assume N = 1100 0010
    7th bit = 1
    6th bit = 1
    5th bit = 0
    4th bit = 0
    3rd bit = 0
    2nd bit =0
    1st bit = 1
    last bit = 0
    set 5th bit so N = 1110 0010
    set 2nd bit so N = 1100 0110
    N = (N | (1 << (K - 1)))
    N = 1100 0010 |(1 << (K -1)
    What will be the value of K if I want to set the 5th bit position?
  9. #9
    Nov 2006
    Brazil
    9,105
    30,356
    42
    Blog Entries
    9
    K-1 = 5
    k = 5 - (-1)
    k=6
    I'm sure you could have inferred this by yourself.
  10. #10
    Feb 2018
    53
    636
    K-1 = 5
    k = 5 - (-1)
    k=6
    N = 1100 0010 |(1 << 6)
    N = 1100 0010 | 0000 0001 << 6
    N = 1100 0010 | 01000000
    N = 1100 0010
    5th bit is not set, N should be 1110 0010
  11. #11
    Points: 83,894, Level: 70
    Apr 2014
    17,063
    83,894
    70
    Hi
    In a byte there are 8 bits.
    Usually they are called bit 0 up to bit 7 in descending order (7654 3210)
    If you use this nomenclature (bit0 ... bit7) then
    * if you want to set bit 5 you have to use "5" as shift operator. 1 << 5
    To avoid confusion we prefer this nomenclature.
    In your example
    You use "5th" bit as an equivalent to "bit5". But then you need to call the most right bit "0th bit". This is quite unusual to have a "0th something".
    No one would say "I am the 0th son of my parents".
  12. #12
    Feb 2018
    53
    636
    Hi
    I think I understood how does bit set in byte
    Byte = 1100 0010 (MSB to LSB) (76543210)
    0000 0001 < 1 = 00000010
    0000 0001 < 2 = 00000100
    0000 0001 < 3 = 00001000
    0000 0001 < 4 = 00010000
    0000 0001 < 5 = 001000000
    0000 0001 < 6 = 01000000
    0000 0001 < 7 = 10000000
    Set Bit 7th
    Code C - [expand]
    N = 1100 0010 | 0000 0001 < 7
    N = 1100 0010 |  10000000
    N =1100 0010
    Set Bit 6th
    Code C - [expand]
    1100 0010 | 0000 0001 < 6
    1100 0010
    Set Bit 5th
    Code C - [expand]
    1100 0010 | 0000 0001 < 5
    N = 1100 0010 | 001000000
    N = 1110 0010
