Repeat Cycle using timer application
nayakajit87
Member level 5
I am using 4Mhz crystal with pic16F886 using timer interrupt 1ms. In below
Here i could able to display set value and process value.During ontime Setvalue displayed on bottom Dissect(value) & process value on top Dissect_2(value) For Off time Setvalue displayed on TOp Dissect_2(value) & process value on bottomDissect(value)
First cycle where first ontime with process value and second offtime value with process value work properly. Now this cycle has to repeat But in third cycle it will display on time and offtime Set value.But wont process the value.
My working should be I have 2 time on time and Off time.It has been set initial stage. First on time come into picture. where bottom display show set value and top display show process value. when counter reached then top display show off time value as setted and bottom value as process value. cycle keep repeat
My question is how can i solve below issue.
Code C# - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
#include <htc.h>
#include <stdio.h>
#include <math.h>
#include "delay.h"
#define _XTAL_FREQ 4000000
__CONFIG(FOSC_HS & WDTE_ON& PWRTE_ON & CP_OFF & BOREN_ON & LVP_OFF & CPD_OFF  & DEBUG_OFF&MCLRE_ON &BOREN_ON&FCMEN_ON &WRT_OFF);
#define RLY_DRV1        RB4
#define DISPCLK         RB5
#define DISPDATA        RB6
#define STROBE          RB7
#define RLY_DRV2     RC0
int Bottom_Value = 0;
unsigned int Top_Display = 0;
unsigned int Float_Value;
unsigned int InG_value;
unsigned int On_Time=0;
unsigned int Off_Time=0;
unsigned char Cylic_Flag=0;
unsigned char LED_MS_Flag = 0;
unsigned char LED_SeMi_Flag = 0;
unsigned char LED_HM_Flag = 0;
unsigned char ON_Prg_Flag = 0;
unsigned char Off_Prg_Flag = 0;
unsigned char RLY_Off_Flag=0;
unsigned char On_Int_Flag=1;
unsigned int Hour = 0;
unsigned int Min = 0;
unsigned int Sec = 0;
unsigned int MSec = 0;
const unsigned char DISPTABLE[27] = {0x03,0x9F,0x25,0x0D,0x99,0x49,0x41,0x1F,0x01,0x09,0x11,0x83,0x31,
                                     //0  //1  //2  //3  //4  //5  //6  //7  //8  //9  //A  //U  //P
                                     0xD1,0xE3,0x89,0x63,0xE1,0xF5,0xC1,0x61,0x71,0xF3,0xFD,0xD5,0x85,0xFF
unsigned char LEDBuffer_1[8];
void Dissect(unsigned int Value) { // Spliting of process value in digits form
  unsigned char a, Temp;
  for (a = 8; a >= 5; a--) {
    Temp = Value % 10;
    Value = Value / 10;
    LEDBuffer_1[a - 1] = DISPTABLE[Temp];
void Dissect_2(unsigned int Value) { // Spliting of process value in digits form
  for (a = 4; a >= 1; a--) {
    Temp = Value % 10;
    Value = Value / 10;
void RLY_CHG_CHK() {
  RLY_Off_Flag = 0;
  if (Sub_Relay == 1) {
    RLY_DRV2 = 1;
    if (Sub_Time == 1) {
      RLY_DRV1 = 0;
    } else if (Sub_Time == 2) {
      RLY_DRV1 = 1;
    } else if (Sub_Time == 3) {
      if (Cylic_Flag == 1) {
        RLY_DRV1 = 0;
      } else if (Cylic_Flag == 0) {
        RLY_DRV1 = 1;
  } else if (Sub_Relay == 2) { // 2 Change Over relay section
      RLY_DRV2 = 0;
      RLY_DRV1 = 0;
      RLY_DRV2 = 1;
      RLY_DRV1 = 1;
        RLY_DRV1 = 0;
        RLY_DRV2 = 0;
        RLY_DRV1 = 1;
        RLY_DRV2 = 1;
void Relay_OFF()
  RLY_Off_Flag = 1;
    RLY_DRV2 = 0;
      RLY_DRV1 = 1;
      RLY_DRV1 = 1;
        RLY_DRV1 = 0;
        RLY_DRV1 = 1;
  } else
      RLY_DRV2 = 1;
      RLY_DRV1 = 1;
      RLY_DRV2 = 0;
      RLY_DRV1 = 0;
        RLY_DRV1 = 1;
        RLY_DRV2 = 1;
        RLY_DRV1 = 0;
        RLY_DRV2 = 0;
void Msec_Function() {
  if (LED_MS_Flag == 1) {
    if (On_Int_Flag == 0) {
        if (RLY_Off_Flag == 0) {
          //On_Time=2525;
          RLY_CHG_CHK();
        LED_HM_Flag = 0; //min_Hour Flag
        LED_SeMi_Flag = 0; // Sec & min FLag
        LED_MS = 1;
        LED_SS = 0;
        LED_HM = 1;
          Dissect_2(On_Time);
          Dissect(Bottom_Value);
          //Off_Time=3636;
          RLY_CHG_CHK();
        LED_MS = 1;
        LED_SS = 0;
        LED_HM = 1;
          Dissect_2(Top_Display);
          Dissect(Off_Time);
        //Cylic_Flag=0;
void Process_RUN_MODE() {
    Msec_Function();
void main() {
  On_Time = 2525;
  Off_Time = 3535;
  Sub_Time = 3;
  Sub_Relay = 1;
  LED_MS_Flag = 1;
  On_Int_Flag = 0;
  Cylic_Flag = 0;
  while (1) {
    Process_RUN_MODE();
void interrupt isr(void) {
  asm("clrwdt");
  if (TMR1IF) {
    TMR1IF = 0;
    TMR1H = 0xFE;
    TMR1L = 0x0C;
        if (On_Time > Bottom_Value) {
            Bottom_Value = (Sec * 1000) + MSec;
          } else if (LED_SeMi_Flag == 1) {
            Bottom_Value = (Min * 100) + Sec;
          } else if (LED_HM_Flag == 1) {
            Bottom_Value = (Hour * 100) + Min;
        } else
        if (On_Time == Bottom_Value) {
          //Cylic_Flag=1;
          Relay_OFF();
          //Off_Time=3456;
          On_Int_Flag = 0;
          //Bottom_Value=0;
        if (Off_Time > Top_Display) {
            Top_Display = (Sec * 1000) + MSec;
            Top_Display = (Min * 100) + Sec;
            Top_Display = (Hour * 100) + Min;
        } else
        if (Top_Display == Off_Time) {
          //Cylic_Flag=0;
          Relay_OFF();
          On_Int_Flag = 0;
    MSec++;
    if (MSec >= 1000) {
      MSec = 0;
      Sec = Sec + 1;
    } else if (Sec >= 59) {
      Sec = 0;
      Min = Min + 1;
    } else if (Min >= 59) {
      Min = 0;
      Hour = Hour + 1;
    } else if (Hour > 99) {
      Hour = 0;
    Display();
I don't understsnd your code ... I'm not that experienced with C
But generally the ISR code should be as short as possible.
You do a lot of stuff in the ISR.
Most of it can simply be processed in the main loop.
Do only the jobs in the ISR that need to be fast or precisely timed.
I can't see that switching a relay ON/OFF needs that precise timing. ... but maybe it does, it depends on your application..
Added:
does it make sense?
Your code is undocumented and we don't have useful information about the function.
What about flow chart, timing diagram, state diagram? You should have this already. If not, then thats most probably the problem ;-)
Display: It seems you update the display every ms. But eyes and brain are not that fast. You should not update a display more often than very 250ms. Just set a flag every 250ms in the ISR, to inform the main loop that new display data should be processed.
Display related activity will be done ISR routine. Else you cant see the changes in dsplay. Currently in my code i am not turning on and off the relay function. I am concentrating on only displaying on time and off time process value.
It doing its job but only for 1 cycle.
it will load on time value and change to off time value when it reaches respective values.
in 3rd cycle, what ever ontime and offtime it will load into display.
as i understood it is not loading value of ontime and offtime after first cycle.
Code is running for 1ms so content also get updated for 1sec
I explained the timing issues to nayakajit87 and how to structure the ISR efficiently in a previous post but it has been ignored.
As well as that, I can't see where 'LED_MS_Flag" gets reset anywhere or for that matter what it actually does. It seems to be initialized at '1' then checked to see if it is still '1' at various times in the program but never used for anything.
I'll repeat: Just do the timing inside the ISR then get out of it as quickly as possible. Check the variables you update in the ISR in the main code.
What does the "Display()" routine do? If it introduces any delays before returning it might also stop the program running.
If this is true, how can some of my applictions's display work?
And read carefully:
If you use multiplexing techniques (or other requirement) that needs exact timing...you should output the preprocessed data to the display within the ISR. But I recommend that they should be processed in main loop.
--> Keep most of the processing power in main loop. Keep ISR as short as possible.
--> keep precision timing in the ISR.
Based on suggestion . I have modified code . With below code i have tested. In polling mode the
Value Bottom display shows setvalue 2525 and stop at 2525
IT wont continue next cycle.
The code is for only testing purppose. LED_MS_Flag is not reset since i am testing sec and Msec function. Later It will implemented for other function.
For testing of code i am passing fake parameters to evaluate the actual operation.those flags can be later used for further calculation.
The variable declared in main() are onetime executing function. once set always it will be loaded.
	asm("clrwdt");
	if (TMR1IF) {
		TMR1IF = 0;
		TMR1H = 0xFE;
		TMR1L = 0x0C; // timer interrupt for 1ms
		MSec++;
		if (MSec >= 1000) {
			MSec = 0;
			Sec = Sec + 1;
			Sec = 0;
			Min = Min + 1;
			Min = 0;
			Hour = Hour + 1;
			Hour = 0;
		//Display();
void main() {
	On_Time=2525;
	Off_Time=3535;
	Sub_Time=3;
	Sub_Relay=1;
	LED_MS_Flag=1;
	On_Int_Flag=0;
	Cylic_Flag=0;
	while(1) {
		Process_RUN_MODE();
		Cylic_Fun_CHK();
void Cylic_Fun_CHK() {
	//Cyclic function start from Here......................................................................
			} else
					Cylic_Flag = 1;
					Relay_OFF();
					On_Int_Flag = 0;
					Bottom_Value = 0;
			} else
				if (Off_Time == Top_Display) {
					Cylic_Flag = 0;
					Relay_OFF();
					On_Int_Flag = 0;
					Top_Display = 0;
					//Off_Time =0;
		Msec_Function();
I'm still confused about what this code is supposed to do and in particular how it produces the display. Am I correct in thinking the lines:
#define DISPCLK         RB5
are digit drive signals to two 7-segment LEDs? If so, how are two different four digit numbers displayed?
Perhaps a schematic to see how you have it connected would help.
