Results 1 to 4 of 4
    Full Member level 5
    Points: 3,162, Level: 13
    May 2010
    Poland
    248
    3,162
    13
    Rise times and fall times of fast transistors seem way too long
    In the data sheet of a 400 MHz transistor I found fall time = 60 ns. Clearly these are contradictory specifications
    - trise and tfall should be at least an order of magnitude shorter.
    Should I believe that fT is specified correctly? (e.g. 2SA2088FRAT106Q transistor).
    Points: 82,022, Level: 69
    Apr 2014
    16,646
    82,022
    69
    Re: Rise times and fall times of fast transistors seem way too long
    400MHz is for small signal (non saturated) analog mode....where the gain = 1
    60ns is for large signal, saturated, switching mode.
    Two completely different situations.
    Points: 265,419, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,373
    265,419
    100
    Apart from the difference between saturated switching and small signal amplifier operation, do you understand the meaning of fT? It's the frequency where the small signal current gain would drop to unity.
    Points: 41,024, Level: 49
    Mar 2008
    USA
    6,607
    41,024
    49
    fT of an unloaded transistor, or one in a 50 ohm ideal
    test setup and rise/fall times with a spec load, 10-90%
    are not at all the same condition.
    Fall time is drive current and (load+Miller) capacitance.
