Results 1 to 3 of 3
    Points: 34,911, Level: 45
    Sep 2008
    cambridge
    7,255
    34,911
    45
    Inductance of 100m of coiled up cable on winch (twisted pair or just two strand)
    The cable seen at 4:50 of this..
    https://www.youtube.com/watch?v=GzTMaXfLFb4
    ..is 100m long. Since it comprises "go" and "return", the inductance of the coiled up cable on the winch will be very low.
    Do you know a formula to calculate this?
    1...for twisted pair cable
    2...for side-by-side cable
    ..or just a rough estimate of the coiled up cable inductance as shown here (100m).
    I'd guess 200uH for the inductance...since mains cable (side-by-side) is approx 1uH per metre when un-coiled...so estimate 2uH per metre for coiled up.
    I'd estimate 70uH if it was twisted pair.
    What are your thoughts?
    Points: 265,442, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,381
    265,442
    100
    Re: Inductance of coile dup cbale on winch (twisted pair or just two strand)
    Inductance of a balanced line depends on conductor geometry. Twist has no considerable effect, except for slightly increasing the effective length.
    Conductive material in the vicinity (e.g. a cable shield or other wires) tends to reduce inductance. Mutual inductance in a coil can increase TP inductance, but due to arbitrary coupling factor sign, I would expect only a low average increase. Factor 2 sounds unrealistic.
    Points: 13,375, Level: 27
    Aug 2015
    Melbourne
    2,195
    13,375
    27
    agreed - twisted pair and side by side is essentially the same thing, for send & return coiling has no effect ...
    as to the drones - eventually the weight of the wire will be a severe limiting factor for height - and distance from spool ...
