Results 1 to 5 of 5
    Newbie level 1
    Points: 20, Level: 1
    Feb 2020
    20
    soldering with silver content
    Hey guys.When is a solder with silver content used?
    Points: 84,023, Level: 70
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,826
    84,023
    70
    Re: soldering with silver content
    Most electrical solder contains some silver but higher concentrations are used when soldering some surface mount components with silver doped end connections. It helps to limit the migration of metal from the component itself into the joint if the alloy is partially saturated.
    There are also special RF applications where skin resistance has to be minimized.
    Points: 54,156, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    13,200
    54,156
    56
    I have silver solder in wire form. It's stronger than normal tin/lead solder.
    Silver type is useful to fix metal parts where the fix should be done quickly and occupy a small area. The aim is to avoid generating excess heat which discolors adjacent metal. Example, eyeglass frames, jewelry.
    I keep a separate soldering iron which I use only for the silver type.
    Points: 799, Level: 6
    Oct 2016
    Volos, Greece
    41
    799
    I use "silver content wire" or solder when I am making high quality metrology / calibration gear for my Blog.
    A good example this is making bridges for a seven stages resistor decade box.
    https://www.ittsb.eu/High-Precision-...stors-Box.html
    The dark side of silver this is corrosion at humid environment.
    But in my applications they are living in clean workshop environment, with just a bit of regular dust in it.
    Newbie level 2
    Points: 140, Level: 1
    Jul 2019
    140
    Silver solder is used to connect stainless steel to itself or to other steels when low temperatures are required.
    High quality, usually custom-built, bicycle frames are often silver-brazed since the very thin-walled tubes might be heat-treated, and heat must be kept at a minimum to avoid annealing the material.
