Results 1 to 3 of 3
    Junior Member level 2
    Points: 528, Level: 4
    Dec 2017
    20
    528
    Monte Carlo simulation with TSMC 0.13u
    Hi all,
    After reading some threats in the forum, I couldn't find an answer to my question - I am using a TSMC 130nm RF spice model and trying to simulate mismatch in Cadence ADXL with MonteCarlo analysis, with no luck.
    I was able to simulate corners with no problem (SS,FF,TT,SF,FS) but when choosing a MonteCarlo corner (or at least thinking I am choosing such one). I receive the following error :
    I chose the corner - "MAC", which I think is the best fit for MonteCarlo as you can see :
    I am using the following TSMC RF SPICE MODEL : Click image for larger version.
    my MOSFET is "nch".
    Appreciate your help on what I am doing wrong/where to look/etc,etc...
    Thanks,
    Daniel
    Advanced Member level 3
    Points: 6,338, Level: 18
    Dominik Przyborowski's Avatar
    Jun 2013
    Norway
    808
    6,338
    18
    Re: Monte Carlo simulation with TSMC 0.13u
    Everything is in process documentation.
    You should use devices with postfix "_mac" . You can switch you devices manually or by script (if exist in your PDK setup)
    Dec 2017
    20
    528
    I just found this in the PDK -
    >>>>spice model notice<<<<
    The current version of spice model still doesn't support Monte Carlo simulation.
    The Monte Carlo model will be support in the feature.
