Results 1 to 6 of 6
    Newbie level 5
    Points: 139, Level: 1
    Sep 2019
    9
    139
    Import pspice .cir file into cadence
    I am trying to import pspice .cir file into cadence spectre and I have successively generated the schematic graph. However, when I run the simulation, some errors appear.
    Here are the errors
    Here are the settings in schematic
ID:	157881Click image for larger version.
ID:	157882Click image for larger version.
ID:	157883Click image for larger version.
    Here is the .cir file
    * AD817 SPICE Macro-model
    * Description: Amplifier
    * Generic Desc: High Speed, Low Power Wide Vs Op Amp
    * Developed by: ARG / ADI
    * Revision History: 08/10/2012 - Updated to new header style
    * 1.0 (11/1992)
    * Copyright 1993, 2012 by Analog Devices, Inc.
    * Refer to http://www.analog.com/Analog_Root/static/techSupport/designTools/spiceModels/license/spice_general.html for License Statement.  Use of this model
    * indicates your acceptance with the terms and provisions in the License Statement.
    * BEGIN Notes:
    * Not Modeled:
    * Parameters modeled include:
    * END Notes
    * Node assignments
    *                non-inverting input
    *                |  inverting input
    *                |  |  positive supply
    *                |  |  |  negative supply
    *                |  |  |  |  output
    .SUBCKT AD817    2  1  99 50 46
    * INPUT STAGE AND POLE AT 160MHZ
    I1   8    50   1E-3
    Q1   4    1    6    QN
    Q2   5    3    7    QN
    CIN  1    2    1.5PF
    R1   99   4    1.188K
    R2   99   5    1.188K
    C1   4    5    4.187E-13
    R3   6    8    1.137K
    R4   7    8    1.137K
    IOS  1    2    12.5E-9
    EOS  3    2    POLY(1) (15,98) 0.5E-3 10
    * GAIN STAGE AND DOMINANT POLE AT 8.8KHZ
    EREF 98   0    POLY(2) (99,0) (50,0) 0 0.5 0.5
    G1   98   9    (4,5) .8415E-3
    R5   9    98   5.942E6
    C2   9    98   3.045E-12
    D1   9    10   DX
    D2   11   9    DX
    V1   99   10   1.83
    V2   11   50   1.83
    * COMMON MODE STAGE WITH ZERO AT 3.16KHZ
    ECM  14   98   POLY(2) (1,98) (2,98) 0 0.5 0.5
    R7   14   15   1E6
    C4   14   15   5.036E-11
    R8   15   98   1
    *POLE AT 120MHZ
    GP2  98   31   (9,98) 1E-6
    RP2  31   98   1E6
    CP2  31   98   1.326E-15
    *ZERO AT 60MHZ
    EZ1  32   98   (31,98) 1E6
    RZ1  32   33   1E6
    RZ2  33   98   1
    CZ1  32   33   2.65E-15
    *ZERO AT 100MHZ
    EZ2  34   98   (33,98) 1E6
    RZ3  34   35   1E6
    RZ4  35   98   1
    CZ2  34   35   1.59E-15
    *POLE AT 120MHZ
    GP3  98   36   (35,98) 1E-6
    RP3  36   98   1E6
    CP3  36   98   1.326E-15
    *POLE AT 160MHZ
    GP10  98   40   (36,98) 1E-6
    RP10  40   98   1E6
    CP10  40   98   .995E-15
    * OUTPUT STAGE
    RO1  99   45   16
    RO2  45   50   16
    G7   45   99   (99,40) 62.5E-3
    G8   50   45   (40,50) 62.5E-3
    G9   98   60   (45,40) 62.5E-3
    D7   60   61   DX
    D8   62   60   DX
    V7   61   98   DC 0
    V8   98   62   DC 0
    GSY  99   50   (99,50) 7.692E-6
    FSY  99   50   POLY(2) V7 V8 5.77E-3  1  1
    D9   41   45   DX
    D10  45   42   DX
    V5   40   41   0.04
    V6   42   40   0.04
    LO   45   46   .06E-9
    * MODELS USED
    .MODEL DX D
    .MODEL QN NPN(BF=151.52)
    .ENDS
    Points: 17,800, Level: 32
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,742
    17,800
    32
    Re: Import pspice .cir file into cadence
    Show me netlist for spectre.
    Importing as schematic is not needed at all.
    Use spice netlist directly, since spectre can read spice netlist.
    Points: 31,267, Level: 43
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,591
    31,267
    43
    Let me tell you the Best Method to insert a SPICE model into Cadence ADE..
    Create a SPICE View in Library Manager, Cadence ADE will open up a simple Text Editor the copy and paste SPICE Contents into supplied space then save it.
    After that, create symbol view from this text editor and ADE will will automatically create for you.Then while you're doing simulations, Add "spice" view into View list.( Environment tab )
    Newbie level 5
    Sep 2019
    9
    139
    Hi, thanks for your reply,
    I followed your steps and it shows this error:
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,591
    31,267
    43
    Quote Originally Posted by kokokosini123 View Post
    The message is clear.. Add +mts command in spectre options field
    Newbie level 5
    Sep 2019
    9
    139
    Quote Originally Posted by BigBoss View Post
    Sorry, could you give me some clue? Where could I find spectre options field?
