Results 1 to 5 of 5
    Member level 5
    Points: 818, Level: 6
    Oct 2017
    86
    818
    How to glue a heat sink on a IC
    Hi All,
    I have to glue a heat sink on a chip which is getting super hot. The dimension are width 6.3mm and length. Anyone could recommend something to glue it?. I have though in thermal tape but it wont secure the heat sink enough...
    Thanks,
    Winsu
    Last edited by FvM; 20th February 2020 at 17:47. Reason: Moved to appropriate section
    Points: 265,324, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,357
    265,324
    100
    Re: How to glue a heat sink on a IC
    You can use epoxy glue. I presume, it's a plastic package without dedicated thermal interface. Don't expect strong cooling effect by the heat sink. Most heat will be dissipated through pins and PCB anyway.
    Member level 5
    Oct 2017
    86
    818
    Yes, it is unfortunately the case. What other solutions could be done. Moving tracks and filled the area with copper?. Plated vias underneath of the chip?.
    Points: 41,018, Level: 49
    Mar 2008
    USA
    6,607
    41,018
    49
    "Arctic Silver" epoxy is (or was) popular for PC CPU /
    GPU heat sink attach.
    What kind of package and how the heat flows, may
    be a concern. Putting the heat sink on a plastic package
    that has no thermal features (slug etc.) may still leave
    you an inferior thermal path. Look at heat spreaders
    as a means to "involve" more of the package surface
    if the sink is smaller than package outline (facing area
    from paddle and leadframe to sink, over plastic thickness,
    is the deal).
    Member level 5
    Oct 2017
    86
    818
    the package is a DFN-8 and the heat sink covers the whole thing ( it even standouts a bit) I have used araldite to glue the chip...Tomorrow I will run a test to see if it has improved...
    Any ideas on the layout?, what I could change in the layout to make it better?.
