Results 1 to 5 of 5
    Newbie level 5
    Points: 701, Level: 5
    Nov 2016
    10
    701
    Coupler or Combiner?
    hi
    could i use directional coupler instead of combiner?
    i need to combine two signal but hasn't any combiner.
    if i use coupler, what happen for signal? is that degrade?
    freq=uhf.
    tnx
    Junior Member level 2
    Points: 684, Level: 5
    Anomis's Avatar
    Mar 2017
    South Korea
    20
    684
    Re: Coupler or Combiner?
    Quote Originally Posted by mehdu View Post
    hi
    freq=uhf.
    tnx
    you are possible using a quadrature hybrid coupler (a type of directional coupler) as a combiner at the cost of 3 dB attenuation at branches 2 and 3/ output at 1 port and isolation matched load at port 4 ( please refer to Pozar book: microwave engineering for more detail).
    Points: 8,660, Level: 22
    Nov 2009
    Italy
    1,165
    8,660
    22
    In principle you can use a "standard" directional coupler, if you just want to mix two different signals, but depends from your application (f.i have you got some specific phase impairement requirement ?) and the maximum attenuation you can afford.
    Take into account that the signal on the direct line will be attenuate by just some tenth of dB while that sent to the coupled line will be attenuated by the coupling factor. To equalize the attenuation you have to insert a fixed attenuator from the generator toward the direct line.
    Newbie level 5
    Nov 2016
    10
    701
    Quote Originally Posted by albbg View Post
    i want combine two signal from signal generator.so i can adjust the level attenuated by coupling factor.
    indeed, my question about degrade that signals.is that degrade?
    Nov 2009
    Italy
    1,165
    8,660
    22
    The directional coupler is a linear passive device, then the signals will not get distorted.
