Results 1 to 5 of 5
    Points: 503, Level: 4
    May 2018
    36
    503
    72 pin SIMM pinout and circuit
    Hi to all,
    I do not understand what is the correct pinout of the old 72 pin SIMM memories, some of the documents that I have found are conflicting for some PINs.
    I am creating a project to drive several SIMMs with one FPGA, could you show me some reference scheme?
    Points: 82,180, Level: 69
    Apr 2014
    16,676
    82,180
    69
    Re: 72 pin SIMM pinout and circuit
    If you are the designer, the you should give specifications.
    Otherwise we could guess a hundred posts....
    May 2018
    36
    503
    Hi see these documents:
    https://pinouts.ru/Memory/Simm72_pinout.shtml
    https://allpinouts.org/pinouts/conne...mm-ecc-72-pin/
    PIN 19 is Not connected or is Address10?
    PIN 29 is Address11 or Data16?
    PIN 41 is /CAS1 or Address10?
    And so on..
    Points: 265,504, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,390
    265,504
    100
    If you experience contradicting hearsay specs, why not refer to major manufacturers datasheets instead?
    Apr 2014
    16,676
    82,180
    69
    A fully agree with FvM.
    The first results of a simple internet search "simm sdram specification" leads you the big manufacturers... and reliable informations.
