+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 1
    Points: 17, Level: 1
    Join Date
    Feb 2020
    Posts
    Points
    17
    Level
    PIC Program for Multilevel Inverter
    Click image for larger version.
    I'm having very hard time writing code for pic16f877a for my solar powered multilevel inverter with the above switching strategy. Can someone help me write this code? PLEASEEEE...
    •   AltAdvertisement
  2. #2
    Super Moderator
    Points: 54,148, Level: 56
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    13,200
    Points
    54,148
    Level
    56
    Re: PIC Program for Multilevel Inverter
    Your timing scheme has 14 steps. Create 7 arrays named SW1(), SW2(), etc.
    In each array create 14 elements which contain the successive state (0 or 1) of that switch.
    Go through a for-next loop X=1 to 14.
    Examine SW1(X). If it's 1, then turn it on. If zero then turn it off.
    Examine SW2(X). Etc through all switches.
    Increment X until X=14.
    Repeat the for-next loop.
    1 members found this post helpful.
    •   AltAdvertisement
  3. #3
    Super Moderator
    Points: 81,996, Level: 69
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    16,646
    Points
    81,996
    Level
    69
    A question....
    * Do you want to write code on your own? --> then start with an idea, a piece of paper, a pencil, a flow chart....
    * Or do you want someone else write code for you? --> then consider to pay for it.
    Klaus
    Please don´t contact me via PM, because there is no time to respond to them. No friend requests. Thank you.
