Page 1 of 2 1 2 LastLast
Results 1 to 20 of 31
    Advanced Member level 2
    Points: 4,016, Level: 14
    imranahmed's Avatar
    Dec 2011
    Karachi,Pakistan
    650
    4,016
    14
    Glow LED on specified counter values 0-500 in 89c52 uC
    Please let me know I have 89c52 and I want to program in this manner that counter counts by external interrupt by push button 0 to 500.
    When it reaches 10 glow LED1 and at 15 glow LED2 at 25 glow LED1 again at 30 glow LED2 and so on till 500.
    unsigned int Counter = 0;
    void ext0_isr(void) interrupt 0
    Counter++;
    main()
    if(Counter == 10)
    LED1 = 1;
    else if(Counter == 15)
    LED2 = 1;
    else if(Counter == 25)
    LED1 = 1;
    and so on till 500
    In above for 0 to 500 LED1 and LED2 glow alternatively with gap of 10 and 5.
    I want to know is there any possibility for shorter code size.
    IMRAN
    Points: 54,216, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    13,219
    54,216
    56
    Re: Glow LED on specified counter values 0-500 in 89c52 uC
    It looks as though you light led1 every 15 counts starting at 10.
    Likewise led2 lights every 15 counts starting at 15.
    This can be done by a simple formula, for each led.
    Advanced Member level 3
    Points: 3,642, Level: 14
    baileychic's Avatar
    Aug 2017
    728
    3,642
    14
    Try this.
    	Counter++;
    main()
    if(Counter % 10)LED1 = 1;
    else 	LED2 = 1;
    or
    main()
    elseif(!(Counter % 10))	LED2 = 1;
    imranahmed's Avatar
    Dec 2011
    Karachi,Pakistan
    650
    4,016
    14
    Yes exactly.Please hint
    I will try it, you gave in previous thread great answer this answer also looks good I will try and let you know.
    IMRAN
    Points: 82,180, Level: 69
    Apr 2014
    16,681
    82,180
    69
    In the given code I miss how the LEDs are set to "0".
    imranahmed's Avatar
    Dec 2011
    Karachi,Pakistan
    650
    4,016
    14
    unsigned char flag = 0;
    Counter++;
    main()
    if(Counter == 10 && flag == 0)
    LED1 = 1;
    delay(1000);
    LED1 = 0;
    flag = 1;
    else if(Counter == 15 && flag == 1)
    LED2 = 1;
    delay(1000);
    LED2 = 0;
    flag = 0;
    else if(Counter == 25 && flag == 0)
    LED1 = 1;
    delay(1000);
    LED1 = 0;
    flag = 1;
    else if(Counter == 30 && flag == 1)
    LED2 = 1;
    delay(1000);
    LED2 = 0;
    flag  = 0
    else if(Counter == 40 && flag == 0)
    LED1 = 1;
    delay(1000);
    LED1 = 0;
    flag = 1;
    and so on till 500
    I want to make it shorter by using formula or FOR LOOP or other LOOP, any hint?
    IMRAN
  7. #7
    Apr 2014
    16,681
    82,180
    69
    As "counter" is used both in main and isr, it should be declared "volatile".
    If "counter" needs multiple access to be processed (i.e. 16 bit variable on a 8 bit microcontroller) you should use "atomic" access.
    For hobbyists this often is no problem, but for reliable industrial solutions it's very important to avoid malfunction.
    If you want repeated function of LED glow every x events,
    * consider to reset (or better: subtract x from) the counter
    * or use the modulo operator
  8. #8
    imranahmed's Avatar
    Dec 2011
    Karachi,Pakistan
    650
    4,016
    14
    I also used while loop for forever operation.I will try your suggestions and will let you know.
    Counter++;
    main()
    while(1){
    LED1 = 1;
    delay(1000);
    LED1 = 0;
    flag = 1;
    LED2 = 1;
    delay(1000);
    LED2 = 0;
    flag = 0;
    LED1 = 1;
    delay(1000);
    LED1 = 0;
    flag = 1;
    LED2 = 1;
    delay(1000);
    LED2 = 0;
    flag  = 0
    LED1 = 1;
    delay(1000);
    LED1 = 0;
    flag = 1;
    and so on till 500
    IMRAN
  9. #9
    Points: 84,121, Level: 70
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,842
    84,121
    70
    Subtract the base values 10 and 15 from the Counter value and if the result modulo 10 and 15 is zero, turn the LED on, otherwise turn it off.
    Make sure 'Counter' is declared volatile.
  10. #10
    imranahmed's Avatar
    Dec 2011
    Karachi,Pakistan
    650
    4,016
    14
    Ok doing it.
    IMRAN
  11. #11
    baileychic's Avatar
    Aug 2017
    728
    3,642
    14
    Try this.
    volatile unsigned int Counter = 0;
    volaile unsigned int oldCounter = 0;
    	Counter++;
    	if(oldCounter != Counter) {
    		oldCounter = Counter;
    		LED1 = 0;
    		LED2 = 0;
    main()
    if(Counter % 10)LED1 = ~LED1;
    elseif(!(Counter % 10))	LED2 = ~LED2;
    delay(1000);
  12. #12
    imranahmed's Avatar
    Dec 2011
    Karachi,Pakistan
    650
    4,016
    14
    Quote Originally Posted by baileychic View Post
    Try this.
    	Counter++;
    		LED1 = 0;
    		LED2 = 0;
    main()
    delay(1000);
    LED1 should start from 10 and with gap 15 it will lit-up, means 10,25,40,55,70....... till 500.
    and
    LED2 should start from 15 and with gap 15 it will lit-up, means 15,30,45,60,75........till 500.
    I tried this but LED was glowing at start of Counter means at Counter value 1.
    I tried this, but only at value 10 of counter LED was litting-up but I also want to lit-up to whole sequence 0-500 first start at 10 then 25 then 40 then 55 then 70.....so on 500.
    Same as applies for 15 but how to resolve please more hints needed.
    	if((!(10 - Counter) % 10) && flag == 0)
    		LED1 = 1;
                    delay(1000);
                    LED = 0;
                    flag = 1;
    IMRAN
  13. #13
    baileychic's Avatar
    Aug 2017
    728
    3,642
    14
    Very simple. Try this.
    	Counter++;
    main()
    if(Counter >= 10) && ((Counter % 15) == 10) { LED2 = 0; LED1 = ~LED1; }
    elseif((Counter >= 15) && ((Counter % 10) == 0)){ LED1 = 0; LED2 = ~LED2;}
    delay(1000);
  14. #14
    imranahmed's Avatar
    Dec 2011
    Karachi,Pakistan
    650
    4,016
    14
    	Counter++;
    main()
    delay(1000);
    It is working only Counter value of 10 only after 10 onwards it is not working.
    I tried only for if(Counter >= 10) && ((Counter % 15) == 10) this condition for LED1 only.
    IMRAN
  15. #15
    baileychic's Avatar
    Aug 2017
    728
    3,642
    14
    Missing brackets.
    	Counter++;
    main()
    if((Counter >= 10) && ((Counter % 15) == 10)) { LED2 = 0; LED1 = ~LED1; }
    delay(1000);
  16. #16
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    13,842
    84,121
    70
    from my post #9:
    Subtract the increment from the counter then check the modulo for zero.
    You did it the other way around! Subtracting Counter from 10 results in a 'negative' rollover of the unsigned int!
    if(((Counter - 10) % 10) == 0) LED1 = 1; else LED1 = 0;
    if(((Counter - 15) % 15) == 0) LED2 = 1; else LED2 = 0;
  17. #17
    Apr 2014
    16,681
    82,180
    69
    (Counter - 10) % 10) is the same as (Counter % 10)
    (Counter - 15) % 15) is the same as (Counter % 15)
  18. #18
    imranahmed's Avatar
    Dec 2011
    Karachi,Pakistan
    650
    4,016
    14
    Problem Solved
    I used simple formula not huge coding needed but unfortunately no one in thread could provide proper answer, however problem solved.
    volatile unsigned int Counter=0, h=10, v=15;
    Counter++;
    main()
    while(1)
    if(Counter == h)         // for LED1
    LED1=1;
    delay(1000);
    LED1=0;
    h+=15;
    if(Counter == v)         // for LED2
    LED2=1;
    delay(1000);
    LED2=0;
    v+=15;
    IMRAN
  19. #19
    Points: 30,286, Level: 42
    andre_teprom's Avatar
    Nov 2006
    Brazil
    9,064
    30,286
    42
    Blog Entries
    9
    Problem 'solved' with a bad programming style, consider next time using state machine handling delays with flags instead of closed loop delays. I would not be surprised if you reopen the discussion reporting that with the above working code you are unable to do well other tasks besides this LED blinky itself. By the way, with the code above, you perform the required task as expected only in the first iteration.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
  20. #20
    imranahmed's Avatar
    Dec 2011
    Karachi,Pakistan
    650
    4,016
    14
    Quote Originally Posted by andre_teprom View Post
    Yes you saying alright but please let me know how to do in best way.How to use state machine handling delays with flags?
    Please let me know.
    Are you taking about only delays (bad programming style)?
    IMRAN
