Results 1 to 4 of 4
    Advanced Member level 3
    Points: 6,663, Level: 19
    Jun 2009
    India
    858
    6,663
    19
    Fast amplifier using one stage OP AMP
    I am trying to make an amplifier to amplify pulses of a microsecond from an optical detector. The amplitude is of the order of 100 mV and a gain of about 50 is desirable.
    Any one may please help providing a link to suitable resource and suggest a readily available operational Amplifier IC
    Points: 5,094, Level: 16
    Nov 2013
    747
    5,094
    16
    Re: Fast amplifier using one stage OP AMP
    How much is the expected rising/falling time value? Why do you need 5V amplitude, what is your load? Any other specifications (consumption, delay, etc.)?
    "Try SCE to AUX." /John Aaron/
    Points: 80,975, Level: 69
    Apr 2014
    16,420
    80,975
    69
    There are standard Opamps that will be suitable.
    Just use the selection guides provided by Opamp manufacturers and distributors.
    For faster solutions you may look for "current feedback Opamps".
    Points: 6,800, Level: 19
    Feb 2014
    975
    6,800
    19
    Great problem to explore in a simulator like LTSpice which has good models for almost all Analog devices (Linear) opamps covering all types and bandwidths.
    There you can see how well they can reproduce the pulse you expect.
    Note that high gain and high bandwidth often benefits from having more than one stage.
