Results 1 to 5 of 5
    Member level 5
    Points: 2,128, Level: 10
    Jun 2010
    Regina, Canada
    81
    2,128
    10
    Programming ESP-32 ESP-12
    Can we program ESP-32/ESP-12 other than Arduino compiler? like XC or some other C Programmer?
    Points: 30,285, Level: 42
    andre_teprom's Avatar
    Nov 2006
    Brazil
    9,062
    30,285
    42
    Blog Entries
    9
    Re: Programming ESP-32 ESP-12
    There is the ESP-IDF toolset available that compiles in C++, however since its is not very friendly to deal even with simple applications, it is recommended only for those who are familiar with low level of programming to interface with its hardware modules. Only in the specific case of Espressif ESP32/8266 microcontrollers, unless your application requires otherwise, I particularly recommend considering Arduino, which has currently mature libraries and even uses the above toolchain compiling in the background. As Arduino is an object-oriented language nativelly made over an RTOS, it is even possible to use resources that obviously would not be possible to implement in a bare metal C as you supposedly want.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    Points: 8,101, Level: 21
    Jan 2015
    1,137
    8,101
    21
    What is the problem you are having with the Arduino environment?
    Have you looked at PlatformIO? however without knowing the underlying issue, it is hard to say if this will be any better.
    Susan
    Member level 5
    Jun 2010
    Regina, Canada
    81
    2,128
    10
    Arduino does not look efficient there is lots of overhead and code debugging is really hard, I tried PlatformIO looks like need to invest lots of time to understand project setup/configurations
    Jan 2015
    1,137
    8,101
    21
    Somewhere along the line you need to put in some effort.
    Arduino code can be very efficient but I do agree about the debugging. There are lots of libraries around that can get you going quite quickly.
    I use PlatformIO relatively easily and I admit I don't fully understand all of the internal systems but that does not stop me using it. (It has stopped me trying to port a new version of the Espressif ESP-IDF to the environment but that is a different level of complexity.)
    Susan
