Results 1 to 5 of 5
    Advanced Member level 2
    Points: 4,016, Level: 14
    imranahmed's Avatar
    Dec 2011
    Karachi,Pakistan
    650
    4,016
    14
    Atmel 89c52 interfacing with AT24c512 EEPROM
    I WANT TO KNOW THAT I WROTE A CODE SAVING COUNTER VALUES IN EEPROM AT24c512 BUT PROBLEM IS THAT I COULD NOT ABLE TO STORE VALUE ABOVE 255, I WANT TO STORE VALUE 0-500.
    PLEASE LET ME KNOW HOW TO DO?
    void ex0_isr (void) interrupt 0
    ex0_isr_counter++;   // Increment the count by button
    void main()
    ex0_isr_counter = read_byte_from_eeprom(0);
    while(1)
    write_byte_to_eeprom(0 , ex0_isr_counter);
    display(ex0_isr_counter);
    IMRAN
    Points: 81,064, Level: 69
    Apr 2014
    16,448
    81,064
    69
    Re: Atmel 89c52 interfacing with AT24c512 EEPROM
    For sure you know that one byte has a limited range of 0...255 (unsigned).
    This really is very basic knowledge.
    --> use two or more bytes.
    imranahmed's Avatar
    Dec 2011
    Karachi,Pakistan
    650
    4,016
    14
    Yes I know, counter value increases 0 to 500 when reaches 255 it got stored but above values are not storing?
    I want to know how store values above 255?
    IMRAN
    Advanced Member level 3
    Points: 3,604, Level: 14
    baileychic's Avatar
    Aug 2017
    719
    3,604
    14
    Your
    ex0_isr_counter
    should be of int type
    and the new code should be
    write_byte_to_eeprom(0 , (ex0_isr_counter & 0xFF));
    write_byte_to_eeprom(1 , ((ex0_isr_counter & 0xFF00) >> 8));
    imranahmed's Avatar
    Dec 2011
    Karachi,Pakistan
    650
    4,016
    14
    Yes it is already integer type but you provide best solution.Its great, you are good.
    IMRAN
