Results 1 to 5 of 5
    Newbie level 3
    Points: 309, Level: 3
    Aug 2018
    309
    parasitic cell blocking
    Hi ,
    At the moment I am trying to perform parasitic extraction using PVS-Quantus to get the RLC parasitics of the metal stack (routing).
    the Pcell of my the transistor already includes RLC parasitics , I want this part of the layout to be blocked from parasitic extraction to avoid parasitics double counting
    To do that :
    • I preserved the Pcell during PVS LVS using preserve_cell_list in PVL.
    • Then I introduced the cell to be blocked which is the Pcell to PVS Quantus tool in a txt file as pcellname_CDNS* .
    checking fT and fmax of the transitor I can see that there is parasitics double counting (10-15% degradation).
    any idea how solve this issue ?
    Br.
    Full Member level 4
    Points: 1,626, Level: 9
    Jan 2019
    Ireland
    223
    1,626
    9
    Re: parasitic cell blocking
    Have you changed the corner after extraction for simulation? Typically schematic simulations and extracted simulations are done with different corners.
    Newbie level 3
    Aug 2018
    309
    Quote Originally Posted by vivekroy View Post
    I am using nominal (typical) corner for both schematic and extraction.
    Full Member level 4
    Jan 2019
    Ireland
    223
    1,626
    9
    There is something called a "pre" sim and "post" sim.. Check your PDK documents.
    Which technology is this?
    Advanced Member level 2
    Points: 5,788, Level: 18
    Feb 2008
    560
    5,788
    18
    Quote Originally Posted by SAMIRAZ View Post
    Hi ,
    To do that :
    Br.
    I think it should be expected that performance deteriorates when you instantiate your cell at higher hierarchy, due to interconnects parasitics.
    Why do you think your parasitics in the pcell are double counted?
